01-19-2013, 06:22 PM | #1 |
Rep 117
PYSpeed| KW suspension special promotion!
PYSpeed - KW Automotive (click for details) KW Coilover Kit V1 Features: - 2 = Front height adjustable by threaded shock bodies. Rear height adjustable by adjustable spring perch. - 37 = Vehicles equipped with electronic damper control: Electronic damper control needs to be disabled. Disable modules available through KW. Please check KW accessories list. - 67 = For vehicles equipped with electronic damping DCC, the electronic damping control needs to be deactivated. Deactivation kit part no. 68510141 Variant 1 - Spirited - balanced with KW factory pre-set dampening The ideal systems for customers wishing to rely on the experience of our engineers yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sportly driving, comfort and safety. - Preset for optimum performance for a sportly yet comfortable ride quality - 'inox-line' stainless steel technology - individually height adjustable - TÜV-tested lowering range - High-quality components for long life - Comprehensive documentation for ease of use Lowering Range - Front: 0.6"-1.8" - Rear: 0.4"-1.4" KW Coilover Kit V3 Features: - 2 = Front height adjustable by threaded shock bodies. Rear height adjustable by adjustable spring perch. - 37 = Vehicles equipped with electronic damper control: Electronic damper control needs to be disabled. Disable modules available through KW. Please check KW accessories list. - 67 = For vehicles equipped with electronic damping DCC, the electronic damping control needs to be deactivated. Deactivation kit part no. 68510141 Variant 3 - Race technology for the road with adjustable compression & rebound dampening The new Variant 3 ist state-of-the-art technology for the skilled and experienced driver. The separate and independet compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed-range, while the highspeed set-up, so decisive for driving comfort, has been pre set by our engineers. - Independently adjustable damping technology - rebound and compression damping - 'inox-line' stainless steel technology - Individual height adjustment - TÜV-tested adjustment parameters - High quality components for long life - Comprohensive documentation for ease of use Lowering Range - Front: 0.6"-1.8" - Rear: 0.4"-1.4" KW Coilover Kit Clubsport Features: - 2 = Front height adjustable by threaded shock bodies. Rear height adjustable by adjustable spring perch. - 6 = Wheel spacers may be necessary if using stock tires. Clubsport - KW Clubsport Coilovers KW Clubsport coilovers have been developed with KW motorsports technology. Designed for car enthusiasts who favours racetrack performance over regular street use. The KW Clubsports provide excellent tuning and handling characteristics. Lowering Range - Front: 0.8"-2.0" - Rear: 0.6"-1.5" Last edited by Brandon@P; 01-24-2013 at 06:16 PM.. |
02-09-2013, 02:56 PM | #10 |
409
Rep 3,479
Drives: 19 M2C 6MT
Price of V3?
03-04-2013, 10:06 PM | #17 |
915
Rep 3,456
Drives: Harrop E90 M3
Separate prices for CS for an E90 M3 wEDC and a 1M please.
Thanks |
