11-19-2012, 09:24 PM | #1 |
44
Rep 387
Brake pads glazed?
How do you know if your brakes are glazed over or not?
Recently added hawk hps pads and I don't see an improvement. In fact I feel like I can't even trigger the abs anymore on threshold braking. Any recommendations? |
11-19-2012, 10:16 PM | #2 |
Dog Listener
703
Rep 7,850
According to the description of these pads, they have a slightly higher friction (torque) output than ceramic pads. I've found the amount of brake torque with ceramic pads to be way outside my comfort level (as in they don't seem to "stop" like stock or Stoptech Street Performance pads). You're not going to get a really high torque pad for street use of course, but I like a little bite (progressive linear bite).
Based on the pad description, I'd kind of guess what you're feeling is what is similar to going from a track pad (say DTC-60s back to street pads). Seems like there's no bite, but it's relative. Is it really the case that you can't get ABS to engage if you really get on them, hard? I'm sure you bedded them, so that's probably a moot point. Pedal is okay, no air in system? Probably another moot point. I guess that covers the obvious stuff, maybe you like a more aggressive compound? Let's see what others say, I could be missing something! |
11-20-2012, 07:03 PM | #3 |
44
Rep 387
I guess I was exaggerating on the abs. I think you're spot on with regard to how much torque is needed and the lack of bite. I have a track day coming up, and will see how my braking zones are affected.
I did bed them and there is no air in the lines, so I hope that's it. If they are glazed, what's the best way to correct it. |
11-20-2012, 07:29 PM | #4 |
460
Rep 4,531
I wouldn't be running those as track pads IMO.
If you arent confident in the pads, then you won't be confident in your car. Last edited by Kgolf31; 11-20-2012 at 08:42 PM.. |
11-20-2012, 07:38 PM | #5 | |
Dog Listener
703
Rep 7,850
I kind of doubt that's the case, and this is just the lower friction co-efficient of the pads. I think you have to face it, you like more aggressive pads! No way you should be running those pads on the track. (I agree with Kgolf.) Per Zeckhausen Hawk HPS high performance street pads have low dust, low noise, and low rotor wear. Slightly higher in friction level than Hawk Ceramic pads with a similar MOT of around 750 degrees F. Not recommended for track use, as their friction level falls off rapidly when the MOT is exceeded.If you're running Rcomps, get some real track pads (or if you're really good at modulation with street tires). For street tires and up to intermediate use, Stoptech Street Performance are pretty good. I haven't roasted mine yet, but they now last about one track day. Running something like DTC-60s on street tires (Star Specs) requires a good degree of control and modulation--it's a very light touch given the greater torque, and pretty easy to lock up the tires/engage ABS. I've ran those my last two track days, and it really requires a change in approach vs. the street and it's really easy to lock them up. I haven't found a good "in between" pad yet that's more capable, but doesn't require Rcomps (not ready for that yet, but I do need a bit more capable pad). |
11-20-2012, 08:00 PM | #6 |
44
Rep 387
These were meant to be a compromise. I had been using the stock pads at the track until now. I'm sure they won't last long.
I would love a more aggressive pad but I hear the squeal is really bad. |
11-20-2012, 08:52 PM | #7 |
Dog Listener
703
Rep 7,850
DTC-60s, HT-10s, Performance Friction--any kind of track pad will squeal like crazy.
But those ST Street Performance pads, they're quiet, less dusty than the stock pads, really good and progressive bite, and have a pretty wide operating temperature. Great street/track pad unless you're an advanced driver (I'm not). |
11-20-2012, 09:48 PM | #8 | ||
460
Rep 4,531
I was planning on running Hawk HT-10s next year. I have HP+ now, but I'm scared I'll fade them at Mid-Ohio (I ran in cold weather last time and they were burning up at the end of session). PFC 08s look like a good candidate (a new combination of PFC 06s IIRC) Quote:
11-20-2012, 10:39 PM | #9 | |
Dog Listener
703
Rep 7,850
11-21-2012, 06:34 AM | #10 | |
27
Rep 341
The 06s are holding up very well, and aren't brutal to the rotors--three weekends on them and the pads are at about 60%. The tires go off long before the first sign of brake fade. Though cold performance isn't bad, they're obnoxious as hell in terms of noise so definitely not a compromise street/track pad. A buddy who usually runs 01s on his M3 tried the 06s and was a little disappointed in their bite, but I think that's the difference between a sprint and an endurance pad.
11-21-2012, 10:25 PM | #11 | |
Dog Listener
703
Rep 7,850
OP, sorry for taking this thread a bit "off track" with the track pad discussion! |
11-21-2012, 11:02 PM | #12 | |
enthusiast
48
Rep 1,695
It reminded me how it is important for the whole to be cohesive. I needed a lot faster car or stickier tires and then it may have worked. That is why it is important to not have more breaking power than the tires can handle. |
11-22-2012, 05:47 PM | #13 | |
27
Rep 341
11-22-2012, 07:34 PM | #14 |
Dog Listener
703
Rep 7,850
Can't speak for Sean, but for me it's how easy it is to engage ABS, which makes threshold (or regressive) braking really difficult. There's very little between threshold and locking up the brakes, and between smooth engagement and them being an on/off switch. And I just barely have to touch the pedal, relative to my Stoptech pads, to get a lot of braking torque (force).
11-22-2012, 08:25 PM | #15 | |
44
Rep 387
No apologies, I should have started this thread before I bought my pads. On a side note, brakes are giving me a lot more feel now that they have a couple hundred miles on them. Wondering why that is, but I guess it doesn't really matter. |
