09-22-2012, 01:42 PM | #1 |
Shosholoza
31
Rep 188
E92 - Schroth Quickfit Pro Install
With 370 posts on the other thread, I thought I would add a simple install guide with pics. It took me about 30 minutes.
1. Buy the mini harnesses - HMS were very prompt 2. Tools: Torx T50 socket; torque wrench for 30 ft pounds; a vice with pliers for bending the Schroth brackets 3. Front: Pop the rubber cover off the Torx bolt at the front of the seatbelt rail 4. Undo the T50 bolt 5. Determine how much you want to bend and twist the Schroth bracket. Do it. I tried to get the angle and twist so that it aligned with the direction the belt would pull. 6. Tighten the T50 bolt to 30 ft pounds 7. Trim the rubber boot so that it fits back over the T50 both with the Schroth bracket 8. Rear: Remove the seat cushion - pull up, some effort is required 9. Undo the T50 bolt 10. Determine how much you want to bend and twist the Schroth bracket. Do it. I tried to get the angle and twist so that it aligned with the direction the belt would pull. 11. Tighten the T50 bolt to 30 ft pounds. I did not use the 13mm nut an washers provided by Schroth, because the factory T50 bolt fits just fine 12. Reinstall the seat cushion
SOLD...E92 M3, Competition Package, MDCT, Ground Control Adjustable Camber plates, StopTech 380 BBK, OEM exhaust mod
09-22-2012, 02:10 PM | #2 |
128
Rep 1,144
Man I'd really prefer it was a crash tested solution in the 3 series like the E46 setup was. I'm not sure PCA will allow that setup BTW. They will not allow 4-point setups, though I did get them to give the E46 coupe quickfit pro an exception because it's DOT approved in that car.
Someone showed up at lonestar PCA last weekend with what look like your setup in an E92, and I didn't call them on it - but technically I should have. |
09-03-2013, 01:26 PM | #3 | |
2289
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
09-03-2013, 02:23 PM | #4 |
115
Rep 1,470
Directions 3-7 are not the only place to put the stub piece. I placed it under the seat bracket guide using that bolt. That places the belt further forward and more equal in position to the one up against the center console. This is more critical for shorter passengers like my wife that really move the seat forward at the track. She is 5'4"
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
09-23-2013, 08:27 PM | #5 |
52
Rep 589
Drives: BMW 1M
The belts for e9X have been released now, so no need to use the mini belts anymore.
#446 of 740
07-19-2021, 08:42 AM | #7 |
1930
Rep 1,896
Drives: E92 M3
They're not meant to restrain an adult in an accident. The weight limit for the LATCH hooks is below 100 lbs for child and car seat combined so attaching harnesses there would be a terrible idea.
e92BMW///M3126.00 |
