07-05-2012, 10:15 AM | #1 |
776
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
Apex square setup question
Let me know if this will fit. Thanks in advance
2011 e92 ZCP Apex 18x9.5 et 35 w/ 275/35/18 all around will these fit with no rubbing. I have searched and searched and could not find any clear answer. Adam
07-05-2012, 10:33 AM | #2 |
818
Rep 7,887
I would think that they are a too positive setup to have enough tire clearance at the front strut.My 18x10 setup with 275/35's only has about 2-3mm of clearance.
07-05-2012, 10:48 AM | #3 |
776
Rep 1,718
So add spacers on the front?
07-05-2012, 11:03 AM | #4 |
818
Rep 7,887
07-05-2012, 11:11 AM | #5 |
776
Rep 1,718
Stock brakes or struts?
07-05-2012, 03:46 PM | #6 |
203
Rep 1,164
I'm planning on doing a Apex 18x10 ET25 square setup with 275/35-18's also, and I was thinking I would need 10mm spacers on fronts to clear strut. Hoping I won't need them, but was planning on it.
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL |
07-05-2012, 04:37 PM | #8 |
818
Rep 7,887
The Apex 18X10's @ 25p are perfect fit for the front without spacers.
07-06-2012, 01:58 PM | #10 | ||
BimmerPost Supporting Vendor
445
Rep 1,658
18x9.5" ET35 was not designed for use on the E9X M3, but it does technically work. The M3 is low offset both front and rear. With the right tire size the front will fit cleanly, but the rear will be very inboard. The rear will need 12-20mm spacers for proper fitment. 18x9.5" ET35 will just barely clear the strut tube with a 265/35/18 street tire. 275/35/18 would definitely touch the strut tube. R-componds would be even worse. The ideal offset for the E9X M3 is 22-25mm with a 9.5" wheel. We would recommend a 12mm front spacer when used with this wheel size. But this would result in having to spend money on a total of 4 spacers just to fit the wheels. 18x9.5" ET22 is the recommended size for the E9X M3. This can be used front and rear with a 275/35/18 tire with no issues, and no need for spacers. Quote:
07-06-2012, 05:48 PM | #11 |
776
Rep 1,718
Got spacers today and fit is perfect. the price on the set I bought was to good to pass so buying spacers where not a big deal.
07-14-2012, 01:56 PM | #12 |
16
Rep 355
Drives: 2011 E92
I'm 18x10" sq no issue. I would think 18x9.5 sq would cause more heat in the rears.
How does it look?
2011 M3 Dakar Yellow-Black Leather-Comp Pkg-DCT-Akra Evo-AP BBK Front-VOLK RE30/BBS GT4 18x10" Square 1995 M3 Boston Green - Chipped - Ground Control Coilovers - APEX ARC8 Past: 2005 Porsche Boxster S-Silver-6spd-Fabspeed Exhaust |
07-17-2012, 05:35 PM | #13 | |
730
Rep 3,971
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
09-03-2012, 12:09 AM | #14 |
203
Rep 1,164
Thanks for the inputs, yes my 18x10ET25 square setup did not require spacer on fronts to clear strut. I thought the fronts stuck out much more than rears, and so placed the 10mm spacers on back instead. I have two track days on new setup and no problems to report. I'm running 35-38psi hot with -1.6 camber up front. I am planning to use the new Vorshlag camber plates as soon as they are available.
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL Last edited by ortho281; 09-03-2012 at 09:29 AM.. |
