06-02-2012, 09:18 PM | #1 |
86
Rep 847
Headlights
My left headlight went out today so thinking about replacing the bulb tomorrow. Is it a standard part that I can get at Autozone or should I order the BMW part? I'm assuming it's an easy DIY to replace the bulb.
06-03-2012, 09:25 AM | #2 |
45
Rep 556
Drives: 2003 ESS TS1 Z4
Just go to autozone, get the Sylvania's.
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit. |
06-03-2012, 02:21 PM | #4 |
86
Rep 847
Stupid Q so pardon my ignorance!
So I looked at the manual and apparently it's an H7 55w bulb. I see that there are two types available online: halogen and xenon. How can I tell which one I have? |
06-04-2012, 11:19 AM | #5 |
Dog Listener
707
Rep 7,850
I don't think the 03s came with xenon, could be wrong, but it's probably halogen. If you pull the bulb, it should have a part number you could use to x-ref against a new bulb.
06-06-2012, 11:59 AM | #7 |
Rep 328
+1
Must have been a separate option at the time?
the stable:
2003 BMW Z4 3.0i 2020 Mitsubishi Outlander SE 2021 Jeep Gladiator Rubicon |
06-06-2012, 01:37 PM | #8 |
Rep 16
There's different ways to tell. Xenon lights are white and bright, halogens put out a a yellow light, not as bright. Also, if you have xenons they have auto leveling, when you turn on your car at night the headlights go down and back up.
Z roadster
06-06-2012, 03:53 PM | #9 |
#dubspec
6339
Rep 5,201
h7s didnt come in xenon
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
06-06-2012, 05:11 PM | #10 |
86
Rep 847
Thanks guys! Based on all the info I think it's regular halogen, which is good seeing how they're so cheap! Heading out to Autozone today to get the bulb :>
