05-23-2012, 06:25 PM | #1 |
BimmerPost Supporting Vendor
308
Rep 4,002
▀▄ eas | Full Auxilary Gauge Solutions for your BMW!
EAS now offers full solutions for gauges for the BMW community, providing you with everything necessary to install gauges on your car while retaining an OEM feel.
Innovate Gauges MTX Digital Boost & Shift Light Gauge The new Innovate Motorsports MTX Digital Series “Dual Function” Gauges are now available! The 52mm gauges feature a water resistant casing, interchangeable faceplates and bezels, locking connectors for simplified installation, and MTS serial connections used to connect with other Innovate devices for logging to your PC, iPhone, or LM-2. Display Range - Boost: -29 inHG to 43.5 PSI (-1 to 3 BAR) - Shift: Up to 20460 RPM Key Features - Display as either inHG/PSI or BAR (Digital Display) - Over Boost Warning (Digital Display) - Progressive Shift Light or Single Stage Shift Light (outer LEDs) MTX Digital Oil Pressure & Temperature Gauge Display Range - Pressure: 0-100 PSI (7 BAR) - Temp: 120-280 °F (49-138 °C) Key Features (Pressure) - Display in either PSI or BAR (Digital Display) - Program Low Oil Pressure Warning (Digital Display) Key Features (Tempertature) - Change exterior LED as a fill bar or light a single indicating LED - Program exterior LED ranges vs. Color - Program unit of measure as °F or °C - Program Oil Temperature Warning (outer LED) MTX Digital Water Temperature & Battery Voltage Gauge Display Range - Water Temp: 120-280 °F (49-138 °C) - Battery V: Volts 6 - 25 VDC Key Features (Water Temperature) - Display in either °F or °C - Water Temp Warning (Digital Display) Key Features (Battery Voltage) - Program exterior LED ranges vs Color - Program Voltage Warning (outer LEDs) MTX Digital Exhaust Gas Temperature (EGT) Gauge Display Range - Temp: 32 - 1999 °F (0-1093 °C) Key Features (Water Temperature) - Change from EGT to CHT range. CHT range allows greater resolution - Display in either °F or °C - Change exterior LED as a fill bar or light a single indicating LED - Program exterior LED ranges vs Color - Program EGT Warning. STACK Gauges Stack’s Pro-Control range of Professional Stepper Motor Analogue Gauges brings total control and driver awareness of critical engine functions. User-configurable minimum and maximum alarms can be set, with one of seven different colours assigned to each. As soon as an alarm level is exceeded, the full dialface changes color. If the level exceeds the alarm by more than 10%, the dialface flashes rapidly to further alert the driver. Available Gauges: - Oil Pressure - Fuel Pressure - Water Temperature - Oil Temperature - Boost Pressure - Exhaust Gas Temperature - Fuel Level (Programmable) - Battery Voltage - Wideband Digital *STACK Gauges are available in Pro-Control and Auxilary models Gauge Hardware Macht Schnell DCT Gauge Boss Allows for the temperature gauges to read both before and after the heat exchanger. Macht Schnell H2O Gauge Boss Perfect fit for the different hoses and water-tight to prevent leaking. Heavy duty hose clamps included. Macht Schnell Oil Distribution Block Allows for Oil Distribution, can be used for Oil Temperature or Oil Pressure Gauges. Compatible with N54/55 and S65. Gauge Mounting Macht Schnell Ashtray Gauge Panel The Macht Schnell gauge panel is an exact component replacement for your stock BMWs ashtray, comfortable housing three 52mm gauges within and angled for easy viewing. The textured finish allows an OEM feel as if this were offered from your local BMW parts counter. Injection molded from ABS plastic, this panel will resist warping or bending in high-heat applications. The smooth textured finish is a perfect match for your BMWs interior, giving the OEM-like appearance you expect. The Macht Schnell ashtray gauge panel mounts using the factory ashtray mounting holes with no drilling or gluing necessary. Macht Schnell Ashtray Gauge Panel – E82/8 1-Series & 1M Macht Schnell Ashtray Gauge Panel – E9x 3-Series & M3 ATI – ePod Steering Wheel Gauge Pod The ATI ePod replaces the original steering column completely and integrates dual 52mm gauge pods. All cables are hidden with the Cable Management System. Each is color and texture matched to ensure the cleanest OEM look available on the market! Note: Gauges are not included. Available for e36 and e46 as well. Ordering: Phone: You can reach us directly by calling 866.669.0705 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Tax: All CA customers will be charged 7.75% CA Sales tax. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday/Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x32 Email: robert@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions.
Robert T. | european auto source (eas)
email: robert@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x21 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by robert @ eas; 12-12-2013 at 04:49 PM.. |
05-31-2012, 06:16 PM | #2 |
2917
Rep 21,727
Contact eas today for all you auxiliary gauge solutions!!
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
05-31-2012, 09:32 PM | #3 |
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Do the Innovate gauges fit in the ashtray gauge panel?
06-01-2012, 11:16 AM | #4 |
2917
Rep 21,727
Yes, they do. The innovate gauges we carry are 52mm's and so is the opening on the gauge panel.
06-13-2012, 06:09 PM | #5 |
308
Rep 4,002
Order your gauges and gauge panels today! Call european auto source today!
email: robert@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x21 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
06-20-2012, 05:05 PM | #6 |
308
Rep 4,002
Contact eas now to order!!!
06-27-2012, 04:06 PM | #7 |
308
Rep 4,002
Call eas for your Auxiliary Gauge Solutions!!
07-11-2012, 11:58 AM | #8 |
308
Rep 4,002
Call eas now!!!
12-19-2012, 01:18 PM | #13 |
308
Rep 4,002
Macht Schnell Gauge Panel
01-02-2013, 07:03 PM | #14 |
2917
Rep 21,727
Call or PM today to get your gauge packages!!
01-24-2013, 03:53 PM | #15 |
308
Rep 4,002
Call eas to purchase your gauges and mounting solutions!
02-23-2016, 11:47 AM | #17 |
2917
Rep 21,727
PM coming your way
