04-24-2012, 10:05 PM | #1 |
17
Rep 251
Bad spark plugs, bad eng coil or my Z4m is allergic to hot weather?
Hello everyone... well, about a month ago after driving the car for few hours here and there.... in a 90 degree temp, the RPMs would drop a little while waiting for the light, then at a diffrent light... the engine stopped. It actually happened about 3 different times on different days.... but now it seems fine although I haven't been driving when the temp is above 85 or so so I don't know if I should order new coils or spark plugs.... or ignore it. what gives?
04-24-2012, 10:20 PM | #2 |
enthusiast
48
Rep 1,695
I am pretty sure that it is not coil or plugs. I have never heard of them being affected by temperature. I would check things that are affected by temperature, like water temperature sensors.
Just my .02 cents but what do I know. |
04-24-2012, 10:32 PM | #3 |
17
Rep 251
True true.... now I'm thinking if I had picked up some sore of bad gasoline. I was planning to remove the plugs to see if anything looks abnormal.... but the phreaken car runs fine now. Now, when I'm at a light I'm constantly paying attention the RPM needle.... I guess I'm paranoid.
04-24-2012, 11:12 PM | #4 |
5330
Rep 1,912
I've had the same issue posted about it here:
http://www.zpost.com/forums/showthread.php?t=656319 Seems a lot of people have experienced this. |
04-25-2012, 12:09 PM | #7 | |
Rep 238
Might also be heat exacerbated by ethanol. |
