04-12-2012, 09:45 AM | #1 |
117
Rep 1,664
Drives: E82 N55 DCT
Front tires wearing extremely fast
I'm going through front tires extremely fast... I do a few driving events, and drive the car fairly hard daily, but still... seems too quick...
I know the answer is probably to check the alignment or buy tires with better wear life... but I installed new suspension, got new wheels and tires, and got an alignment to get this setup. Here was my setup from stock: - KW V2, hard setting - Vorshlag camber plates, -3.5 - M3 front control arms and sway bar - Toe-out 1/4-inch - Running 225/40 Pirelli Pzero System (80% tread life) - Starting Mileage: 13,750 - Uneven Abnormally Fast Wear Mileage: 17,500 (3,750 miles on the tires) - HPDE: 2 back-roads - Took them off to switch to winter tires I had to switch tires, because the Pirelli's were worn, so I installed the stock RFT 215/40 (60% tread life) and changed the setup slightly: - Camber -2 - Less toe-out, approx. 1/8-inch to zero - Starting Mileage: 20,250 - Very even, but abnormally fast wear mileage: 22,500 (2,250 miles on the tires) - HPDE: 2 back-roads - Drag race: 5 runs Any ideas what could be the issue?
04-12-2012, 10:04 AM | #2 |
37
Rep 2,084
Crazy aggressive alignment is supposed to destroy tires. Your second setup is only very aggressive, but it's still well into extra fast wear territory. And didn't I see you post yesterday or the day before that you routinely drive fast enough on street to make your tires scream? What were you expecting to happen to the tires?
04-12-2012, 10:21 AM | #3 | |
117
Rep 1,664
Drives: E82 N55 DCT
04-12-2012, 10:56 AM | #5 |
117
Rep 1,664
Drives: E82 N55 DCT
What does that mean?
04-12-2012, 11:06 AM | #6 |
Resident Kerbalnaut
477
Rep 10,703
Its a well known fact.
Pirellis are fantastic tires in terms of grip and feedback. But their treadlife has always left something to be desired. I, personally, had Pirellis on my 135 once. And I killed that set in about 6k miles without trying to. I know many other people that have had similar experiences with Pirelli. |
04-12-2012, 11:10 AM | #7 | |
117
Rep 1,664
Drives: E82 N55 DCT
But then tearing through the stock 215/40 RFT's just as fast? 60% of the treadlife in a few thousand miles... it has to be the setup or that my car is faster than what it was stock... Stock I used 40% in about 13,000 miles...
04-12-2012, 11:13 AM | #8 | |
Resident Kerbalnaut
477
Rep 10,703
In my experience the stock Bridgestones also wore like crap, but that was four years ago. So it might just be, whats the opposite of rose tinted nostalgia glasses? |
04-12-2012, 05:21 PM | #9 |
37
Rep 2,084
My last set of front tires (Michelin PSS) lasted 8 track days, so about 13 hours of track time.
04-12-2012, 05:26 PM | #10 |
117
Rep 1,998
lets see..... whats wrong...Hmmmmmm
your right foot !!!!!! LOL.. Its heavy car, agressive alignment, fun driving, sticky tires... It all adds up
X1, R58 JCW, M2 in my future if planets align
04-12-2012, 06:06 PM | #11 |
117
Rep 1,664
Drives: E82 N55 DCT
... so this is normal? haha... I can accept that answer.
a couple hundred bucks a few times a year to have fun driving is worth it.
04-12-2012, 08:17 PM | #13 |
122
Rep 2,040
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
I'm having the same issue Bogart but still working on it. I'm on my third set of front tires, second rears. My Porsche used similar tires and one set of fronts would last as long as two sets of rears.
I've had three alignments, corner balancing, etc. My fronts were wearing out on both corners fairly evenly with minor scalloping so we tried taking out a little front toe. When I got my third set of front tires installed (btw my signature is not updated for these tires, I bought a cheap set of 225/35/19 Nitto's) the new tires left me with a slight pull to the right. We readjusted the toe and funny enough my MPG instantly seemed to go up. Still to early to tell about the tires (3k miles and still seem OK) but hopefully it's all just a matter of getting the toe right after lowering our suspensions. Good luck (btw I love your hood, I plan the same when I can afford it).
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
04-12-2012, 10:15 PM | #14 | |
117
Rep 1,664
Drives: E82 N55 DCT
I plan to. The local track, Gateway Motorsports Park was closed for almost 3 years and just re-opened. I've been dragging there, but want to start doing SCCA events and HPDE at their road course. I can't wait.
Thanks! I ended up getting it for $800 w/ the AeroCatch hood pins already installed, used on the forum. Keep your eyes peeled. Also, there are a bunch of carbon fiber foods for sale on ebay for pretty cheap.
04-13-2012, 03:55 AM | #15 |
Resident Kerbalnaut
477
Rep 10,703
one thing to note, check the alignment note really closely. I had a crap alignment once, the car pulled and the steeringwheel tugged.
BMW wanted nothing to do with me because the car was quote "in spec" It turns out that in spec is a 1 degree range on camber and somethine ridiculous on toe and my car, while in spec had one side of the car at one end of the spectrum and the other side of the car at the other end. |
05-23-2012, 09:30 PM | #16 |
117
Rep 1,664
Drives: E82 N55 DCT
Sooo, old thread, but finally can give an update. The culprit was definitely toe.
Specs Before: Front Camber: -2* Total Front Toe: 1.81* !!!!!!!!!!!!!! Rear Camber: -2* Total Rear Toe: 0.33* Specs After: Front Camber: -2* Total Front Toe: 0.27* Rear Camber: -2* Total Rear Toe: 0.23*
