BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
EXXEL Distributions
      04-07-2012, 05:14 PM   #1
ShadeD1
38
Drives: 2011 X5 xDrive 35i
Rear rotors rusted to hub :(
Bought a used stoptech bbk, no problems installing the front. The rear rotors are frozen solid to the hub. 3 of us beat on it for over half an hour with not a wiggle. Does anyone know any tricks to get them off?
      04-07-2012, 06:55 PM   #2
Justin(OKC)
Justin(OKC)'s Avatar
77
Drives: 1988 M3, 1990 M3, 1998 M3/4
1998 BMW M3/4  [10.00]
2011 BMW M3 Sedan  [9.28]
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
2008 BMW 135i - sold  [0.00]
2003 BMW M3 - sold  [0.00]
Do you have the parking brake set? I had this problem one time and it took me awhile to figure out that I had the parking brake on
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black
1998 BMW M3 - Alpine White/Mulberry
2011 BMW 328i racecar - LeMans Blue/Black
      04-07-2012, 07:17 PM   #3
ShadeD1
38
good suggestion, we did have the parking brake set at first but fixed it...tomorrow a larger hammer
      04-07-2012, 07:22 PM   #4
Slapshot9
Slapshot9's Avatar
22
Drives: '08 E90 M3 JzB 6MT
I start with a 3lb dead blow hammer and work my up. Usually after an hour and a 5# engineers hammer, I've broken it loose. Sometimes ruining the rotor.
      04-07-2012, 07:31 PM   #5
Justin(OKC)
77
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
Have you used lots of WD40 or other penetrating oil to help loosen things up?
      04-07-2012, 07:33 PM   #6
ThunderMoose
746
Drives: PY E46 M3 and SG E46 M3
I learned that one last week on my friend's 525. Good to know the e-brake works.
      04-08-2012, 01:55 PM   #7
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
WD-40 and a dead blow will work.
      04-08-2012, 06:45 PM   #8
TXmtrhed
TXmtrhed's Avatar
37
Drives: VO 1M
How about applying heat to the rotor hat (not the hub)? Should cause it to expand at a faster rate since it's thinner.
      04-08-2012, 09:54 PM   #9
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Today, we used a hammer and tapped it on the hub (between the studs). Soon after the rotor finally came off!
      04-08-2012, 09:57 PM   #10
tibra1
No_Country
127
Drives: 2011 ZCP M3 - 2007 335i crashd
A torch is your best friend..
      04-11-2012, 09:38 AM   #11
DARK_M3
105
Drives: 08 E90, 89 Grand Wagoneer
Idk if heating up the metal (to the degree a torch would) is such a good idea. That kind of heat can change the composite and properties of a metal and it's probably ill advised around brake or wheel parts as it might make the metal more brittle.?
      04-11-2012, 10:31 AM   #12
bchang2001
18
Drives: e92 M3
ive always used PB Blaster. let it soak overnight and its magic in the morning!
      04-17-2012, 09:21 AM   #13
edwinm3
edwinm3's Avatar
980
Drives: F82
My vote goes to PB blaster
Grigio Telesto M4, 6MT.
Coyote 5.0 F-150
991 GT3
m3post
