03-27-2012, 12:51 PM | #1 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
How Often Should You Rebuild Calipers?
Whether it's by mileage or years... just curious. I know some people never do and just buy remanufactured ones later... thoughts?
03-27-2012, 12:56 PM | #2 |
25
Rep 296
No reason to unless you are having issues with your brakes. Like a broken seal or something. Just clean up the floating pins during pad changes and you should be good.
03-27-2012, 01:44 PM | #3 |
64
Rep 666
Drives: 2023 Hyundai IONIQ 6 SEL AWD
No need to rebuild calipers unless the dust boot is cracked or has seperated from the caliper housing. Front caliper rebuild kits as well as guide bushing kits are relatively inexpensive. I buy my Ate rebuild kits from Autohaus AZ.
The Z4M rear caliper rebuild is a PITA and much more challenging than the front calipers as illustrated here: http://www.bimmerfest.com/forums/sho...6&postcount=11 The kit, P/N 34 21 6 753 682, must be ordered from a dealer and it isn't cheap and you'll need the special tool, P/N 83 30 0 492 459, to press on the dust boot.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
03-27-2012, 10:26 PM | #4 | |
Rep 238
Dont know about BMW's though. |
03-28-2012, 08:21 PM | #5 |
6 of Diamonds (ret)
82
Rep 566
Only car I ever had to do this on was a 73 vette. Only reason I saw for it was lack of engineering. Piston diameter vs bore was laughable. Pistons rocked in the bore there was so much difference.
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
03-29-2012, 12:09 PM | #7 |
2286
Rep 12,565
Thanks, when I checked the parts list for the front/rear brakes, the diagram & list mentioned rebuild kit was suggested for cars older than 4 years which is why I asked...
