03-25-2012, 03:07 PM | #1 |
223
Rep 1,565
FS: BNIB Vorshlag E82/E9x (non-M3) Camber/Caster Plates & Perches
I have a set of Vorshlag E82/E9x (non-M3) Camber/Caster Plates & Perches set up for OEM springs and KW V1/2/3 struts. These are brand new. Fits both 1-series and 3-series. Does NOT fit 1M or M3. More info can be found on the Vorshlag website: http://www.vorshlag.com/product_info...roducts_id=199 This setup goes for $499 from Vorshlag. Price is $450 with free shipping in the US. Please email bryan@berktechnology.com with any questions. |
03-28-2012, 03:58 PM | #2 |
aiming for 450.....
303
Rep 2,910
I have these on my 135i. Awesome product.
Quote from Ezeedee regarding car mods:
"you're only done when you sell the car " |
03-29-2012, 08:41 PM | #4 |
38
Rep 530
I have a question for you Berk. I talked to Vorshlag about the spring perches and from what I understood after speaking to them, the V3's are actually a narrower diameter spring and that the spring perches for stock, the v1's and v2's won't fit. Any insight on this? I may be interested. Thanks!
KW V3's, Sparco Pro2000's, Vorshlag CP's, JB4, Heat Wrapped Raceland DP's, aFe stg. 2 Sealed Intake, Miro 111's, Hankook RS3's 225/245 (for now), Seibon M3 CF Hood, Turner Motorsports Alum. Radiator, Big Tom IC, BMW Performance bumper.
04-04-2012, 04:36 PM | #5 |
Motorsports Engineer
46
Rep 95
Most KW V3 use 60mm springs. Almost all KW V1 and most KW V2 use springs with an OEM top diameter.
Any spring using an OEM top diameter will work with your perches. If someone needs a pair of 60mm, 2.25" or 2.5" perches, we sell them for $75 a pair including new adapter spools and radial bearings.
Jason McDaniel at Vorshlag
