BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
EXXEL Distributions
      03-24-2012, 04:50 PM   #1
tmntmn
///M
160
Drives: e92 M3/M-DCT
KW Sleeve question for EDC
I'm about to install my sleeve and was wondering If I need to disconnect the battery before I start for EDC Equip cars? Anything else I should look out for?
Thanks in advance
UPDATE! cars feels so much better with the sleeves,
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI
      03-24-2012, 04:53 PM   #2
Sean@PYSpeed.com
Sean@PYSpeed.com's Avatar
306
Drives: 2009 AW E92 M3
Nice seeing you doing something on a rainy day. GL with install!
      03-24-2012, 05:46 PM   #3
Malek@MRF
BimmerPost Supporting Vendor
Malek@MRF's Avatar
731
Drives: E92 M3, E46 M3, G82 M4
You do not need to disconnect the battery.
If you get stuck, feel free to PM, E-mail or call me, I will walk you through it.
Malek
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport.
Facebook | Instagram | Yelp! | Flikr
Phone: 949-233-0448 | E-Mail: info@mrfengineering.com
      03-24-2012, 06:05 PM   #4
tmntmn
///M
160
Malek
Thanks Malek I'll pm you for your number not just in case I get stuck
      03-24-2012, 08:32 PM   #5
Malek@MRF
Malek@MRF's Avatar
731
For sure brotha, but hopefully you won't get stuck at all.
      03-26-2012, 09:38 PM   #6
tmntmn
///M
160
Thanks for the help with the front strut, i got stuck twice since it was my first time installing springs for my car, I spent a good 8-9hrs doing the install with my gf's brother and some help from my dad.
I had to phone for some help a couple times (Thanks Malek and B) but in the end it was a good learning experience, should take 1/4 the time if i have to ever do suspension work on my car again.
Will post up pictures after i get my alignment done.
      03-26-2012, 10:36 PM   #7
THE TECH
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Congrats on the DIY.
      03-26-2012, 10:56 PM   #8
tmntmn
///M
160
Thanks!
Does anyone know if i should wait for the springs to settle before doing an alignment or should i do it ASAP?
      03-26-2012, 11:41 PM   #9
edu09
edu09's Avatar
1507
Drives: 2024 M2, 2022 GT3, 2022 SF90
2022 FERRARI SF90  [10.00]
2024 BMW  [10.00]
2022 PORSCHE 992 GT3  [10.00]
Originally Posted by tmntmn View Post
Thanks!
my alignment was done right after the install, no need to wait for the springs to settle
2024 BMW M2, 2022 Porsche 992 GT3, 2022 Ferrari SF90, 2023 BMW M1000R comp pkg
      03-27-2012, 12:27 AM   #10
tmntmn
///M
160
forgot to thank you and TLP or tip for answering all my questions also
      03-27-2012, 07:30 AM   #11
edu09
edu09's Avatar
1507
2024 BMW  [10.00]
No problem man, glad you had it installed, post some pics when you have a chance
      03-27-2012, 12:57 PM   #12
Malek@MRF
Malek@MRF's Avatar
731
You do not need to wait. You can align the car immediately.
      03-27-2012, 01:20 PM   #13
tmntmn
///M
160
Will do
Thanks Malek i schedule an appoint ASAP
      03-27-2012, 03:23 PM   #14
Boostin FD
Bored all the time
Boostin FD's Avatar
382
Drives: Batmobile
hey bud, I'm curious about the one part where you have to press it in... Did you have trouble with that?
I haven't attempted mine yet, probably will do it this weekend.
Thanks
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3...
It all started with an RX-7 (FD).
      03-27-2012, 03:36 PM   #15
marksae
marksae's Avatar
36
Drives: ///M
Yes, is a press needed to remove the stock perch from the front shocks?
04 E46 M3 6MT - AW / Cinn
93 FD RX-7 Base Manual - BB / Blk
IG: @gearheadtwins
      03-27-2012, 04:33 PM   #16
tmntmn
///M
160
Thanks
pressing in the KW perch wasn't the hard part, getting the OEM perch off was, i had to call Malek and B to get tips on how to remove it off because it was press in pretty good from the factory.
just make sure you have another person to help you remove the perch and reinstall the kw perch.
a press isn't needed but make sure you have some pieces of wood and a hammer to get the kw perch back on the OEM struts.
      03-27-2012, 05:09 PM   #17
Boostin FD
Bored all the time
Boostin FD's Avatar
382
Drives: Batmobile
What are the tips on removing it?
      03-27-2012, 05:48 PM   #18
CarbonFoot
CarbonFoot's Avatar
37
Drives: 2024 M3 CS
Just did mine too. I didn't have much trouble removing the OE perches. Just used a hammer and a blunt brass punch.
Installing the new perches was a bit more interesting for me, because it wasn't really clear how far they needed to go down. I was expecting to feel solid resistance when the sleeve reached it's final position, but I stopped when it felt tight and the top of the sleeve was basically in the same postion as OE, which was about 1/8" below the black plastic cap on the strut. This ended up being way off as it goes down about another half of an inch from there. It's hard to tell in the picture below, but there's a good finger width gap between the sleeve and cap.
Quick note on height adjustment - don't worry about setting the right height in the fronts right out of the box. They are very easy to adjust with the wheel on just by jacking the side up. The rears are going to harder to adjust. You can use my picture as a reference as it resulted in a 3/4" drop in the rear, which was perfect for me.
      03-27-2012, 05:50 PM   #19
tmntmn
///M
160
turn the strut upside down and don't be scared to to hammer it out, make sure you turn it back and forward when on each hit.
      03-27-2012, 05:52 PM   #20
tmntmn
///M
160
did you get an alignment right after the install or your gonna wait until your springs settle? I'm hearing 50/50 about waiting and doing it right after the install and i dont know what to do
      03-27-2012, 06:15 PM   #21
CarbonFoot
CarbonFoot's Avatar
37
Drives: 2024 M3 CS
I waited for a couple of reasons. I wanted to let it settle a bit and decide on a final ride height. Didn't want to throw the geometry off and degrade the handling and feel by going too low. Besides, I wanted to make sure I didn't scrape anything in daily driving. Nothing worse than having trouble getting out of your driveway or office parking lot.
      03-28-2012, 02:22 PM   #22
CarbonFoot
CarbonFoot's Avatar
37
Drives: 2024 M3 CS
Just FYI - my ride height settled by 1/4" in the front and 3/8" in the rear over the course of 3 days after installation.
m3post
