ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > BMW Z4 Photos, Photoshops, Videos and other Media
  TireRack
      03-16-2012, 09:09 PM   #1
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
82
Drives: 2011 E93 335is
M Bumper on my Si
Thanks Dekaliber - Turned out well - may be the only one in Hellrot. MStache is next mod.
2007 Z4Si(gone)
Couple E30 Verts (DD)
2003 330i
2011 E93 335is - current fav
      03-16-2012, 09:25 PM   #2
jra
38
Drives: 2005 z4
Awesome!
      03-16-2012, 09:32 PM   #3
inTgr8r
inTgr8r's Avatar
2435
Drives: M2 Comp
Looks great!
What about black grills?
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      03-16-2012, 10:25 PM   #4
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
I kinda like it better with the silver grills, it's an 3.0si not a 3.0i
Straightaways are for fast cars, Corners are for fast drivers.
      03-16-2012, 11:26 PM   #5
Gripster
Gripster's Avatar
147
Drives: E93 M3
2013 BMW M3  [0.00]
Looks nice. Was it a straightforward swap?
2013 M3 (E93) - ZPP/ZCW/DCT
http://www.bimmerfest.com/forums/image.php?u=26275&type=sigpic&dateline=1208140506
      03-17-2012, 10:55 AM   #6
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
82
Somewhat (still a work in progress)- I used Mister Rodgers thread here (Thanks MR)- it leads to his R&R thread http://www.zpost.com/forums/showthre...ghlight=bumper
Note: the bolts in step 4 of the R&R are Torx bolts not hex.
Couple things on the conversion:
1. The expanding rivets that hold the wheel shrouds to the bumper turned out to be "Blind, Non-reusable" http://www.ecstuning.com/Search/07147172274/ES17028/
While I could have ordered these then I would need the proper tool to put them in and they dont fit any of the heads on my rivet gun(diameter is to big). So I'm gonna order a few of these and see if they work - http://www.ecstuning.com/ES2091812/
2. The covers (# 6 in the picture) that attach to the wheel shrouds and the bumper dont fit the "M" bumper well and they dont allow the bumper to bolt on at the bottom. The Bumper is still secure but I need attachment points for the MStache that is coming shortly. So Im gonna try the "M" ones. http://www.ecstuning.com/ES129347/ and http://www.ecstuning.com/ES129348/
3. The pop up covers for the headlight washers need to be attached somehow. I used 3M Super Strength Moulding Tape. I used the 1/4" width roll. Seems to work very well so far. I cleaned everything with isopropyl first. Applied Tape to the covers, rolled it flatter with a flathead screwdriver before removing the red seal. CAREFULLY trimmed the excess tape that overhangs. Did a test fit before pulling the tape seal. NOTE: be careful when placing the cover on - it will FALL INTO the hole and DROP to the BOTTOM of the bumper . IF this happens go in through the wheel shroud, pull the brake duct out and you can get the missing part. Dont ask how I know, LOL. Then last clean the bumper one more time with alcohol and pull the seal on the tape, position and push down firmly for a minute or so. LET the tape sit for a day before driving. THis also works well for the reflectors too.
4. Last I ended up with the same gap (bottom engine shroud is not long enough) MR talks about in his DIY. When my buddy drops by for dual Mstache day, I may get try his shroud to see if this does the trick. Its not that big a deal but just one of those naggy things.
Not a cheap mod - Money wise I ended up spending about $900
Used Bumper 250 shipped
brake ducts 90, grille 60, 35 for the washer covers, and new badge 23
paint and minor repair on the bumper 460 ( I took them the bare stipped bumper)
Still looking at another 90 for the M Covers (#6 in the pic). So I guess a cool grand all said and done. Course now I want the Mstache........... It goes on and on........ but sure looks pretty.
      03-17-2012, 05:09 PM   #7
Z4MLover2012
15
Drives: 2008 Space Gray Z4M Coupe
It looks great!
      03-17-2012, 05:15 PM   #8
Finnegan
Dog Listener
Finnegan's Avatar
707
Drives: Z4M/. Z3M, E36/46 M3
Does look great!
      03-22-2012, 10:56 PM   #9
-c-
-c-'s Avatar
891
Drives: bmw
Make sure you get the center piece as well. The original won't work and you'll see right through the mesh without it. So you'll need the center splash guard and both end pieces.
      03-22-2012, 11:20 PM   #10
Quickid
Drives: 08 Z4MC, 06 X5 4.4i, 99 323i
Nicely done
      03-23-2012, 12:10 AM   #11
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
82
Are you talking about #8 below? Or maybe something else? Real OEM calls it the transmission air duct.
2007 Z4Si(gone)
2003 330i
      03-23-2012, 05:13 AM   #12
-c-
-c-'s Avatar
891
Drives: bmw
Nope part 6.
Part 8 is a small aluminum part already made that boo boo ... BMW was kind of misleading on the layout of that schematic.
All 3 parts work together and unfortunately non of the SI parts will work. So part 6 plus the two side peices are what you will need. You will also have to drill two new mounting holes in your wheel wells
      03-23-2012, 10:23 AM   #13
Incompatible
55
Drives: 07 AW Z4C 3.0Si
Looks great in hellrot. My preference would be for the black grills, blacked out center section, and no MStache. Any way you do it, it will look good.
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
zpost
