03-16-2012, 01:54 AM | #1 |
76
Rep 724
Why is my camber only at .07?
Note, my camber is at .7 not .07. I mistyped.
I just got an alignment on my 2011 sedan (comp package) and my front camber is only at .7 on both sides. I understand that this cannot be adjusted without pulling the alignment pins, but why would the camber not even be at the minimum .78 BMW alignment spec? Last edited by F9T; 03-19-2012 at 11:36 AM.. |
03-16-2012, 04:40 AM | #2 |
2164
Rep 5,548
Was that the max neg camber the tech could get or did the tech set the camber to be equal on both sides? Do you know if one side is maxed out but the other side still has more range of adjustment?
If the rack hasn't been calibrated recently perhaps the rack measurements are not correct? |
03-16-2012, 09:26 AM | #3 | |
76
Rep 724
03-16-2012, 09:56 AM | #4 |
2164
Rep 5,548
03-17-2012, 06:24 PM | #5 |
BimmerPost Supporting Vendor
731
Rep 3,735
The alignment equipment used may not be accurate or calibrated correctly. If the equipment is not calibrated correctly, everything else will be off as well, especially on the rear end of the car.
All factory M3's I aligned have around -1.0* of camber. I would be more than happy to take a look for you. Malek
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com Last edited by Malek@MRF; 03-17-2012 at 06:29 PM.. |
03-18-2012, 11:55 PM | #6 |
76
Rep 724
Hmmm, you guys are making me a little worried. Although, the BMW specs are based on the car being weighted in accordance with their instructions. My car was aligned without any added weight, which I would assume could make a difference.
03-19-2012, 05:08 AM | #7 | |
2164
Rep 5,548
Where did you get the car aligned - dealership or independent shop? I'd ask them when was the last time their rack was calibrated. |
03-19-2012, 09:49 AM | #9 |
68
Rep 869
are you sure they're measuring in degrees, not minutes or inches or something?
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
03-19-2012, 01:07 PM | #12 |
731
Rep 3,735
At -0.7*, the camber specification is still out as those specifications are made with a a lot more weight than just the drivers weight.
2 68 kg weights on each of the front seats, seats must be set in central position. 1 14 kg weight in trunk Full tank of fuel. The car should have been aligned with weight, at the very least, the drivers weight. Any camber changes will affect toe changes on the rear axle. If your static alignment was set without you or any weight in the car, the camber will shift toward the more negative end with your weight added. As a result, the toe will change as well which will also affect thrust angle. Malek
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
