03-13-2012, 11:06 PM | #1 |
430
Rep 4,650
GB Feeler - VARIS Carbon Fiber Hood for E8X 1-series?
Just wanted to get a feel for how many people would be interested in these VARIS carbon fiber hoods.
They're a bit pricey but a GB is possible to bring the price down significantly, especially costs of shipping. Estimate cost of shipping to be around $600-$800 per hood w/o GB. With GB estimate around $400-$500 per hood. for JPY TO USD conversion use www.xe.com Can be made in 1x1/2x2 twill patterns and in 3 VERSIONS, CARBON FRP / SS CF / FULL VSDC CF They come in 3 different STYLES . OEM style ■ LIGHT WEIGHT BONNET (normal shape) E82 135i: corresponding models Price including tax : ¥ 262,500 (recipe VSDC) Product number : VBB-8201 Price including tax : ¥ 147,000 (carbon) Product number : VBB-8202 Remarks Washer nozzle, striker, kind emblem You can use all genuine. : Because of the lightweight, damper genuine disabled. Stand comes with the original bar. Weight ratio (house) : 18.0kg → 7.0kg genuine carbon Lightweight and high rigidity 3K twill carbon in the surface layer is adopted in its own way of molding VRS, the lay-up Is a carbon bonnet. The process uses a carbon composite VSDC is also (back bone) Inner ribs, while ensuring higher rigidity (A decrease of about 1kg compared with carbon) has been achieved further weight reduction. It's most distinctive addition this hood, so you can install an outlet duct, the shape of the inner rib Is that it has changed from the genuine. In advance to change the shape of the layout of the bone back in order to retrofit duct There. That there is no back bone is cut off when you want the duct by this, without the need for extra processing You can ensure sufficient strength. VENTED HOOD VER 1 ■ COOLING BONNET SYSTEM -1 E82 135i: corresponding models Price including tax : ¥ thirty-seven eight , 000 (recipe VSDC) Product number : VBB-8203 Price including tax : ¥ 262,500 (carbon) Product number : VBB-8204 Price including tax : ¥ 210,000 (Carbon FRP + duct body part) Product number : VBB-8205 Remarks Washer nozzle, striker, yen Bourem kind can be used all genuine. : With duct cover to prevent ingress of rainwater. : Because of the lightweight, damper genuine disabled. Stand comes with the original bar. Weight ratio (house) : 18.0kg → 8.3kg genuine carbon Lay-up using a 12K plain-weave carbon carbon twill 3K, to backup the surface with its own molding method VRS Carbon hood is lightweight and high rigidity. The process uses a carbon composite VSDC is also (back bone) Inner ribs, while ensuring higher rigidity Was further reduced weight. Water temperature can be reduced reliably at high speed circuit and, oil temperature, also, for a special cover with detachable duct, Prevent the infiltration of rainwater that is possible. Water that had accumulated in the cover is designed to fall around the radiator core support through the inner rib Has become. VENTED HOOD VER 2 ■ COOLING BONNET SYSTEM -2 E82 135i: corresponding models Price including tax : ¥ 441,000 (recipe VSDC) Product number : VBB-8206 Price including tax : ¥ 325,500 (carbon) Product number : VBB-8207 Price including tax : ¥ 273,000 (Carbon FRP + duct body part) Product number : VBB-8208 Remarks Washer nozzle, striker, yen Bourem kind can be used all genuine. : Duct to prevent ingress of rainwater into the duct of all With cover. : Because of the lightweight, damper genuine disabled. Stand comes with the original bar. Weight ratio (house) : 18.0kg → 9.5kg genuine carbon Lay-up using a 12K plain-weave carbon carbon twill 3K, to backup the surface with its own molding method VRS Carbon hood is lightweight and high rigidity. The process uses a carbon composite VSDC is also (back bone) Inner ribs, while ensuring higher rigidity Was further reduced weight. Water temperature can be reduced reliably at high speed circuit and, oil temperature, also, for a special cover with detachable duct, Prevent the infiltration of rainwater that is possible. Water that had accumulated in the cover is designed to fall around the radiator core support through the inner rib Has become. In addition, according to the layout of the engine room, set up additional two months the hood duct in the center, Sought a further cooling effect. What do you guys think ? |
03-14-2012, 04:32 PM | #3 |
170
Rep 1,215
+1
MANHART MH2 400 Partout FS: MANHART MHtronik Tuning Box http://www.2addicts.com/forums/showt...5#post18819345 |
03-14-2012, 07:20 PM | #5 | |
734
Rep 3,274
At first I thought those were the prices of the HOODS!!! Seibon makes an OEM style hood for around the price range of the non-GB shipping. I was going to say what great prices.. and then I realized... I'm sure they're higher quality than Seibon's.. but... wow. I am not wealthy enough.
2022 X4 M40i - 2008 135i - 2015 F700GS On Order - 2024 i4 M50 Scruffy's gonna die the way he lived... Mmhm. |
