      03-07-2012, 01:14 PM   #1
pixelblue
pixelblue's Avatar
140
Drives: the silver bullet
2010 135i  [8.90]
damaged icarbon diffuser
hi folks,
noticed this damage to my diffuser . the damage is mainly to the clear coat. scratched and chipped. is it possible to repair this? if not, should I use body filler to fix the chip and then sand and paint the whole diffuser black? at this point I either have to trash it or make the best out of it. appreciate your opinions. thanks,
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
      03-07-2012, 02:38 PM   #2
doublegbmw
Drives: 09 135i
looks like the clear coat is cracked & chipped badly, not an easy repair without damaging carbon fibre material below. Did you scrape something when you were backing in?
      03-07-2012, 02:43 PM   #3
pixelblue
pixelblue's Avatar
140
2010 135i  [8.90]
no it wasn't me. actually the scratches go beneath the car. doubt it was a car that caused the damage. seems like something low rolled into the back. at this point I don't care about the CF finish. I would be ok with spraying it black but would like to fix the damage before doing that
      03-07-2012, 06:02 PM   #4
ken1137
ken1137's Avatar
89
Drives: BMW S1000XR
2009 e90 335i  [6.40]
Try to find good #3000 grit dry/wet SiC sandpaper. This is used on clear coats for cars so should be ok. That being said, don't buy cheap #3000 grit sandpaper, try to find 3M or St Gobain. Good luck.
BMWCCA member
      03-07-2012, 06:38 PM   #5
pixelblue
pixelblue's Avatar
140
2010 135i  [8.90]
thanks but what should I do with the chipped part? body filler?
      03-07-2012, 07:59 PM   #6
ken1137
ken1137's Avatar
89
Drives: BMW S1000XR
oooops...didn't see that. That's gonna be a tough one. Maybe a clear epoxy to blend with the cracks, then polish with #3000 grit paper (?) Sorry, no idea. Maybe a local body shop can recommend a clear epoxy filler.
BMWCCA member
      03-07-2012, 08:22 PM   #7
Harlequin
Harlequin's Avatar
Australia
331
Drives: F32 Coupé
I had a similar problem with a JC Sportline Diffuser I bought. It arrived from the Vendor like this:
It was gonna cost me $500 to send it back to them and they didn't have any replacements in stock so the gave me a bit of a refund and I took it to a local boatbulder who works with fibreglass. He sanded down the clear coat, filled it back in and re-finished it:
Might be worth giving it a try?
      03-07-2012, 08:29 PM   #8
pixelblue
pixelblue's Avatar
140
2010 135i  [8.90]
^ oh wow they did a nice job! so I need to find someone who works on fiberglass. the search begins. thanks for the info Harlequin.
      03-07-2012, 08:35 PM   #9
Harlequin
Harlequin's Avatar
Australia
331
Drives: F32 Coupé
You're welcome mate... I did quite a bit of ringing around so see what could be done and a boat builder seemed to be the best bet... Really happy with the job he did as I was absolutely devastated when it turned up broken...
1addicts
