02-17-2012, 09:57 AM | #1 |
Rep 37
problem with toe, cupping tires - help!
i have a 2011 M3 sedan and have had cupping issues. i have found that my camber and caster stay dead on, but the toe is getting out of spec too quickly and easily. the camber bushings are much larger than the toe bushings. my dealership is digging in to see what we can do. i am hopeful we can install a polybronz bushing to help the situation. here's what i did. knowing that the alignment was out on the last set of cupped tires, i purchased a new set and had an alignment ($150) done when mounting. i then did another alignment ($150) after a couple thousand miles. the camber was still dead on, but the toe was out. So, i did another alignment (don't think they are going to charge me) after a couple thousand miles to find that the camber was dead on, but the toe was out again. so, something is not holding as it relates to toe. i'll let you know what they come back with. anyone else have similar issues/findings? |
02-17-2012, 10:14 AM | #2 |
157
Rep 1,624
How does your car drive on the street, what are the symptoms that you know your toe is off to go get an alignment? Does it pull, the steering wheel off center? Also what are your toe specs?
The alignment settings can change when you go back on the alignment rack even after getting an alignment just before. Just changing where the person who performs the alignment puts the steering wheel, will change the specs. So if they are an inch to left where they did the alignment last time the toe will show up different on the screen because where the steering wheel was set and toe adjusted from. Not saying that is your case but that is possible they are just not setting the steering wheel in the same place each time they align it. So it seems toe is always off |
02-17-2012, 10:48 AM | #3 |
108
Rep 697
I had this problem once when the alignment tech didn't tighten the rear toe bolt properly. After a full track season, it hasn't budged (I check my toe before every track day.
Make sure they're tightening the bolts to spec. |
02-17-2012, 02:55 PM | #4 |
Rep 37
what has caused me to keep checking is the cupping. i have the same mechanic do it each time, on the same machine, i fill the tank full with gas each time, and i am with the mechanic each time. that said, the maching could be out of spec. we'll see what comes back from the puma case. good question, thanks
02-17-2012, 03:46 PM | #5 |
157
Rep 1,624
Ok. If its just your edges of the tires that are cupping that could also be a symptom of under inflated tires.
Let us know what the puma case comes back with. |
05-24-2012, 04:40 PM | #7 |
Rep 37
update: puma resulted in confirmation that toe bushings settle a bit. they are not doing anything about it. i think everything is fine now, but still dissapointing. if they know this, they should at least tell you that you will need to check your alignment frequently during the first 10,000 miles or so.
05-24-2012, 05:58 PM | #8 |
BimmerPost Supporting Vendor
731
Rep 3,735
What are you setting the toe values to?
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
05-24-2012, 06:57 PM | #10 |
731
Rep 3,735
Post the actual values and I can probably help you figure this out.
Tags |
cupping tires toe camber m3 |
