02-11-2012, 09:38 PM | #1 |
Rep 42
KW sleeve over kit install question
I'm in the process of installing the KW sleeve over kit and I'm having one issue: On the rear, when I adjust the collar to set the ride height, the base also rotates. Any tips on how to prevent the base from rotating with the collar?
02-11-2012, 10:59 PM | #2 |
78
Rep 684
Do you by any chance have a large clamp to hold the base? You may have to lower the camber arm to take the spring pressure off of the height adjuster.
02-11-2012, 11:04 PM | #3 |
Rep 42
Yeah, I thought about that and it looks like that's what I'm gonna have to do for now until I get a clear answer as to how to prevent the base from spinning with the collar.
02-11-2012, 11:57 PM | #4 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Use some dry lube on the adjuster threads see if that helps. If you can't hold the base from turning by hand you can use a pair of channel lock pliers just be careful not to damage the base.
Next time try some thrust sheets on the adjuster and lower camber links surfaces, they will help a bit. If you really like to tinker with ride height you will want to install a thrust bearing. The photo below shows a rear spring kit with full height adjustments even with the suspension loaded. However, the purpose of the kit is really to allow a very quick spring change at home or the track. |
