02-08-2012, 08:52 AM | #1 |
Rep 37
Toe Adjustment
Anyone esle finding that toe gets out of alignment too easy? I am tired of tires cupping so quickly, so I had the alignment redone after a few thousand miles and the toe was out of spec. I did not hit any pot holes or anything.
Other's experience? Thanks |
02-08-2012, 09:06 AM | #2 |
One mod leads to another ...
416
Rep 2,900
Is this the front or rear tires? Do you have vibrations in the steering wheel? What type of suspension do you have? Is the cupping on the edge or all over the tread randomly?
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
02-09-2012, 12:14 AM | #4 | |
78
Rep 684
Either way, a good practice is to mark all the eccentric bolts/adjustable links with a pen so that next time, I can tell whether something went out of alignment because of deformation or the bolts/washers simply rotated.
02-10-2012, 08:09 PM | #5 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Cupping isn't fault by the toe out of spec., but more of an indication of a worn out suspension component. Alignment alone will seldom cure the problem. If you have tire issue(badly cupped edges or a worn out tire) that itself can cause a pull.
