01-21-2012, 01:58 PM | #1 |
Rep 61
RE Transmission Mounts and SSK Installed!
I just finished up installing RE tranny mounts and an RE SSK. It definitely improves the feel. Seems to be crisper, but the throws don't feel that much shorter (if at all).
Installing the mounts was pretty easy, aside from tightening the nut where the mount connects with the transmission. I did those last night and couldn't get it very tight because the space was so small. Today I put in the SSK and had to remove the exhaust, so I had more room to tighten everything up. Overall, I would definitely recommend these!
2008 M Roadster [SOLD] (Imola Red/Imola Red/Madeira Trim): Stubby Antenna, CDV delete, ZHP Knob, RE Transmission Mounts, RE SSK (Removed)
2012 335i Sportline (Melbourne Red/Black): Formula One Pinnacle Tint 15%R/30%F |
01-21-2012, 02:00 PM | #2 |
424
Rep 5,329
did you tighten the mounts to Tq spec??? how are you guys getting a Tq wrench up in that space to Tq up properly?? Props for having a go yourself and no paying stupid prices for a garage to do it!!! SSK are not easy to install from what ive seen!!
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
01-21-2012, 02:24 PM | #3 |
Rep 61
Yeah, the SSK was a pain. It took us 4 hours. Taking the exhaust down and getting the rubber boot that seals the shifter into place were the two most time consuming parts. Luckily my friend who does a lot of work on cars helped out (he does corvettes and was pretty shocked at how tightly our cars are packed in). Worth skipping out on paying someone else to do it and its a nice hobby.
As far as the torque specs go, I didn't get a torque wrench up there. I just tightened them until it wouldn't tighten anymore. I figured since the transmission sits on them and the brace is bolted up the the body tightly, there would be enough force to keep them from creeping out.
01-21-2012, 02:36 PM | #4 |
Dog Listener
707
Rep 7,850
Tight enough is probably just fine. (There's really no practical way I could find to use a torque wrench on the top side nuts. Maybe I'm missing the boat). It's 16 ft lbs, which isn't much. There will be excessive vibration with too much torque (causing too much compression of the mounts).
01-22-2012, 01:38 PM | #5 |
Rep 61
While I was driving today, I found that in reverse the SSK contacts the driveshaft. I can hear the metal resonating and as revs increase the shifter starts the vibrate.
Is this slight contact something I should be overly concerned with?
01-22-2012, 03:27 PM | #6 | |
424
Rep 5,329
your ssk should be touch the prop shaft at all......
01-23-2012, 06:51 PM | #7 |
Rep 61
I just sent a note off to RE to see how we can resolve this issue. Luckily their company is based right near my house in NJ. I'm thinking that the pivot point was misplaced during manufacturing. It looks like there are several different notches to change the pivot location (maybe for different model cars?).
02-24-2012, 08:31 PM | #8 |
Rep 61
Removed the SSK
After being stranded in Pittsburgh at 1 am due to the shifter linkage coming apart a few weeks ago, and then being charged $426 to replace a 75 cent clip because I desperately need it fixed that day and didn't have access to a lift, I have decided to remove the RE SSK.
As I mentioned earlier, the kit touches the drive shaft in reverse and the noise has gotten progressively louder it seems. The kit has also become progressively sloppier as it seems to be loosening. RE said the contact is normal "at extreme angles" and after asking for the clearance specs between the bottom of the shifter and the shaft I stopped receiving a response from their company. The dealer (A&L Motors in Pittsburgh) told me that the clip most likely loosened due to the contact and vibrations--RE denies that this is a possibility. Obviously did not have a pleasant experience with the company... A couple hours and $2.00 later, I have the stock shifter back in the car.
02-24-2012, 10:03 PM | #9 |
2304
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.07] |
You should look into the Autosolution ssk...
02-24-2012, 10:24 PM | #10 |
30
Rep 740
Sorry to hear that. For what it's worth, I have the UUC SSK and Option 1 mounts and love the way it feels on the car. If you can deal with the long shipping times and sometimes rude customer service UUC is known for I say switch up to that.
02-25-2012, 08:02 AM | #11 |
424
Rep 5,329
absolutly would not expect the ssk contact i agree with your decision and im kinda dissapointed with REs repsonse...... Are they really saying its acceptable for the shifter to touch the prop shaft at extreme angles?? crazy, and dangerous imo..... Poor show RE.
02-25-2012, 09:48 AM | #12 |
Rep 61
Yeah I couldn't believe it either. And it's sort of embarrassing reversing out of a spot in a parking garage and having a loud ringing coming from my car.
02-25-2012, 10:54 AM | #13 | |
Rep 61
02-25-2012, 11:25 AM | #14 | |
2304
Rep 12,570
Seriously give AS a call, they might make another batch for Z4s. A great AS review here (compared to RE & UUC): http://m3.madrussian.net/review_as_ssk.shtml |
02-25-2012, 02:31 PM | #15 |
80
Rep 1,663
That is terrible, it really shouldn't be touching your drive shaft. If you decide to install the auto solutions one, please post a review.
Nice review dubbed, that site is filled with good stuff. SSKs have come up a few times on here but that's the first review I've seen from someone that has tried all of them.
02-25-2012, 02:53 PM | #16 | |
2435
Rep 11,669
They are expensive if you can't get a GB together but the product itself is fantastic!!! It made a huge improvement with shifting; MUCH more precision and feel.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
02-25-2012, 03:10 PM | #17 |
80
Rep 1,663
Also if you do go for the autosolutions SSK, check out this thread. Maybe ask him to supply chamfered bushings. I think the bushings he supplies are made for his selector rod, however on the Z4M you reuse the stock selector rod, so the bushings don't fit perfectly unless you chamfer them. Was that your experience as well intgr8r?
02-25-2012, 03:25 PM | #18 |
2435
Rep 11,669
^yes, but it was a very minor thing to do.
It was a good thing that someone figured this out because it made a big difference in fitment.
02-25-2012, 06:52 PM | #19 | ||
60
Rep 932
02-25-2012, 10:14 PM | #20 |
Rep 61
Thanks for all the feedback and suggestions guys. I'll be looking into the AS one since so many people have had bad experiences with UUC. When I finally get around to buying it and installing I'll compare it to RE.
02-26-2012, 01:52 AM | #21 |
80
Rep 1,663
I'd sign up for a group buy if you start one.
02-26-2012, 02:04 AM | #22 | |
424
Rep 5,329
Tags |
rogue engineering, short shift kit, ssk, tranny mounts, transmission mounts |
