BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      01-15-2012, 08:42 AM   #1
Dave2
Dave2's Avatar
124
Drives: '11 M3 Convertible
Dinan Stage 2 Suspension
I have decided to get the Dinan Stage 2 suspension for my 2011 E93. I am considering doing the installation myself. Even though I have not done any major work on a car in a few years I have years of automotive and mechanical experience and access to all the necessary tools.
Has anyone done this installation as a DIY? Are there any lessons learned, tricks or tips you could pass along? Or having done the DIY wishing you would have had a professional do it?
Thanks
'11 M3 Convertible | Dinan Stage 2 suspension
      01-15-2012, 03:13 PM   #2
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
Why stage 2? The front bar will just make the car understeer more. Stick with stage 1 or get the Stage 3 with the camber plates.
DSC_3369 by Kit W, on Flickr
      01-15-2012, 07:58 PM   #3
paradocs98
paradocs98's Avatar
394
Drives: M2C
Also keep in mind that this is something like an 8-hour install for a professional mechanic, so be prepared for a significant amount of time...
      01-15-2012, 08:58 PM   #4
Sleeper519
Sleeper519's Avatar
68
Drives: 08 E92 M3 DCT
If I recall correctly, Stage 2 is the Dinan springs, plus the thicker front sway bar from the E93, which you already have on your vert...
I would get Stage 1, plus Ground-Control adjustable camber plates.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20
      01-16-2012, 06:26 AM   #5
cole328
15
Drives: 2011 M3 Convertible
Hmmm...I went with the Stage 2, and I don't notice any appreciable understeer at all car is super nimble, the "drop" was perfect for me, and it's flat as the top of a cop's head in the turns
However, I'm not tracking the car at all, so perhaps you should listen to the more experienced guys on here
      01-16-2012, 10:11 AM   #6
Sleeper519
Sleeper519's Avatar
68
How can Dinan sell you an expensive stage 2 kit for an E93 that has a front sway bar that is the exact same size (28.5mm) as the stock one that is already on the car??
Unless it's a larger diameter than they're advertising on the website, that's fraud.
      01-16-2012, 12:24 PM   #7
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
It's not the same bar. The E93 bars are 28.5 on the ends but thinner across the rest of the bar.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      01-16-2012, 04:18 PM   #8
Dave2
Dave2's Avatar
124
Thanks for the input. This car is a daily driver in all weather conditions. 75% of the time it is driven in commuter mode the other 25% I drive it like I stole it. I have no plans to track the car. Based upon your results it sounds as though the Stage 2 is the correct choice for me.
Still looking for advice from anyone that has done a DYI installation.
      01-16-2012, 07:03 PM   #9
Mbauer
21
Drives: E92 187outx3
I suggest doing it on a lift atleast. Im not sure if you have a spring compressor??? Took me 4 hrs but I do this for a living.
      01-16-2012, 07:12 PM   #10
Sleeper519
Sleeper519's Avatar
68
Thanks for that info. I can climb down quietly from my soapbox now...
      01-16-2012, 08:37 PM   #11
Dave2
Dave2's Avatar
124
I have access to the whole magila; lift, spring compressors, air tools, alignment rack. 4 hours seems like a more realistic estimate. 8 hours seems excessive. Are there any tricks or tips you could impart after having done the install? What alignment numbers did you use?
      01-18-2012, 12:53 AM   #12
Denk
Denk's Avatar
1006
Drives: 2021 X5M
Dinan includes recommended street and track alignment specs with his kits.
Stage 1 and 2 street specs are the same, stage 3 has a little more neg camber front and rear. I can't remember the numbers though. Good luck, I'm sure you'll love the results.
      01-18-2012, 07:02 PM   #13
Dave2
Dave2's Avatar
124
Thanks guys. Just place the order and looking forward to getting to work on this soon.
      01-18-2012, 08:25 PM   #14
kitw
kitw's Avatar
471
I can confirm... the Dinan front bar is solid (or significantly thicker wall) as well. It's really friggin heavy compared to stock and much beefier than the E93 bar.
But... the car already understeers, I'm not sure why you want to increase that.
If you aren't feeling it, you aren't pushing the car...
      01-18-2012, 09:28 PM   #15
Dave2
Dave2's Avatar
124
Why are you under the impression that a stiffer sway bar increases understeer? The stiffer bar reduces body roll. The reduction in body roll reduces weight transfer to the outside wheels during a turn, which in turn tends to equalizes the traction between all tires. This results in less understeer.
If we were to follow the line of logic that a stiffer bar increases understeer, then the logical conclusion would be to simply remove the sway bars to eliminate understeer. I think you imagine what would happen in that case. As you made a turn the body of the car would roll over as it wanted to continue in a straight line (an object in motion will tend to stay in motion, in a straight line, until acted on by an outside force- Isaac Newton) leading to obscene understeer.
      01-18-2012, 09:59 PM   #16
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
No problem...asked the same question and did tons of research...just to throw you off your soap box.
IMO, the more I think about it, the closer I come to the conclusion that the camber plates are a waste.
      01-19-2012, 12:23 AM   #17
klammer
97
Drives: 11 spc gry m3 e90, 19 X5
Have to agree with kitw on the understeer thing, but can't be bothered to explain. On another note, car really handles great on the street and feels nimble and tight, only on track do you really see the weight and understeer problems with this car. Think you'll love the setup.
mods: track ready stuff
      01-19-2012, 01:08 AM   #18
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
A sway bar (aka anti-sway bar aka stabilizer bar) causes the inside wheel to lose grip as cornering load is applied to the outside wheel. It connects both sides so it reduces independent suspension movement.
With a rear sway bar, it makes the car more tail happy because as you corner, the outside wheel is pushed upward which pushes the inside wheel upward through the sway bar which connects both sides. It causes both to take load and lose grip easier.
A front sway bar makes the front give out faster than the rear. It helps turn in as the front feels sharper as the inside and the outside react the same but after initial turn in, it causes the front the understeer as the load on the outside wheel pushes the inside wheel to lose traction as well so both front wheels are pushed upward and you lose front grip.
So generally a front sway bar feels stable at turn in but causes understeer, a rear sway bar causes oversteer... sway bars are sometimes sold in sets so you get the best of both worlds.
      01-19-2012, 04:17 PM   #19
shendrick
Drives: 08 e90 M3, 05 e46 zhp, 07 X3
Increasing roll stiffness up front (stiffer front bar) means the inside front wheel will unweight more in turns increasing understeer.
      01-19-2012, 05:23 PM   #20
Dave2
Dave2's Avatar
124
This may be true of a car with a double wishbone suspension where the camber angle remains consistent through the range of suspension travel.
It is not true with strut-type suspensions, as is the BMW's, where the camber angle changes through the range of suspension travel. With a strut suspension camber becomes more negative as the suspension begins to compress. As the suspension continues to compress the camber becomes more positive. The stiffer front bar will limit the suspension compression and maintain the more negative camber angle.
      01-21-2012, 10:36 AM   #21
Dave2
Dave2's Avatar
124
Looks like my son will be getting a freebie. He has a 135i and it seems the 135 guys are replacing their front sways with the E93 M3 sway bar. So, when i get my Dinan he can have mine. He will be picking up the lunch tab.
      01-26-2012, 06:28 PM   #22
Dave2
Dave2's Avatar
124
The Stage 2 kit has arrived. Installation is scheduled for Monday.
m3post
