01-06-2012, 11:40 AM | #1 |
225
Rep 1,425
Drives: MacanGTS, 991.2GT3, E63wagon
Brembo Caliper on stock rotor
Saw this photo here on the board and figured I would do some research. I figured it was maybe the smaller caliper that brembo sells for their 365mm/345 setup. If this is possible I think it would be an awesome cost effective upgrade if you did just lines, calipers, and mounting hardware. Consumables are much cheaper using the oem rotors but you would still need to use the very expensive pads that fit the Brembo calipers. Another idea was maybe the stoptech 355/355 setup which would be great because the ST60/40 use cheaper pads. Any thoughts? OEM Front Rotor: 360x30 Rear Rotor: 350x24 Smaller Brembo Kit for e92 Front Rotor: 365x34mm Rear Rotor: 345x28mm |
01-06-2012, 11:43 AM | #2 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
My guess is no. Never seen a kit that you could put an upgraded caliper on a stock setup.
01-06-2012, 11:50 AM | #3 |
731
Rep 3,735
We are working on this upgrade right now. I'll keep you guys posted.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
01-06-2012, 11:51 AM | #4 |
307
Rep 13,093
01-06-2012, 11:52 AM | #5 |
80
Rep 961
There are three main considerations in putting a non-OEM caliper onto the OEM rotors:
- the friction face width of the rotor has to match the radial depth of the pads. Racing and aftermarket BBK pads usually range from 49 to 53 mm radial depth. Putting an ST40/60 on a stock E92 M3 front rotor will only work if the rotor annulus is the same width as the pads. - the setback of the rotor has to be such that a caliper bracket can be made that will actually fit. The setback will also determine if the caliper hits the inside of the rim. - the rotor minimum thickness has to be sufficient that the pistons won't fall out of their bores when the pads are worn out From an engineering standpoint, this is not a trivial exercise. |
01-06-2012, 12:00 PM | #6 |
225
Rep 1,425
01-06-2012, 12:31 PM | #8 | |
731
Rep 3,735
The factory rotor is thick enough to support the Brembo Caliper. I will not be designing this for the Stoptech caliper however. You are right, this is definitely not a trivial exercise.
01-06-2012, 12:34 PM | #9 | |
731
Rep 3,735
Through my many times tracking this M3, I have repeatedly realized our factory rotors are great pieces. Our calipers are a major fault.
01-06-2012, 12:40 PM | #11 | |
1889
Rep 5,506
01-06-2012, 12:42 PM | #12 | |
731
Rep 3,735
However, a lot of the Brembo calipers are very similar to one another in this size range.
01-06-2012, 12:49 PM | #13 |
2295
Rep 13,001
Sign me up for your first rear Brembo caliper + OEM rotor application. In Yellow, please.
01-06-2012, 12:51 PM | #14 |
225
Rep 1,425
01-06-2012, 12:59 PM | #15 |
307
Rep 13,093
And to say that I was just gonna drop $3200 on a 380mm front kit. Maybe I will wait.
MahiC88.00 |
01-06-2012, 01:34 PM | #16 |
109
Rep 1,292
Very interested as well.....keep me on your list of potential buyers
01-06-2012, 01:49 PM | #17 | |
225
Rep 1,425
01-06-2012, 02:04 PM | #20 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
OEM rotors may be cheaper but will they last as long as a Brembo 2pc rotor?
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
01-06-2012, 02:08 PM | #21 |
225
Rep 1,425
I am willing to bet under street use they would last just as long and under track use I am ASSUME they would wear at the same rate. I know there are other factors but I am assuming the face of both the brembo and oem rotors is the same material. Also for the price of one set of brembo rotors you can get 2 sets of new OEM rotors.
01-06-2012, 02:09 PM | #22 |
2295
Rep 13,001
If Rotora came up years ago with an relatively inexpensive 4-piston caliper kit for the E46 M3 OEM rotors then I do not see why it cannot be replicated for the E9x M3. Especially if Brembo is involved and all the required ancillaries are done to exact specs.
I bought the first Rotora caliper kit offered in the US back then. The first kit delivered had the front brackets and SS lines done incorrectly -wrong dimensions, seriously. When all was corrected I found the kit to be an excellent upgrade -both visually and performance-wise- over the sliding calipers. No issues that I know of for the last 5 years or so, and 4 different owners of that car. Of course, such an effort is not trivial at all, however that's what R&D is made for. |
