11-20-2011, 02:35 PM | #1 |
62
Rep 167
Rear right wheel bent outwards? (help!)
Alright so one day I'm walking by the E92 being parked normally and notice that the wheel is bent outwards, I didn't think much of it. Later I notice it again and decide to get my hands dirty and check it out.
Long behold, the right wheel is VERY noticeable bent outwards...the left is fine. This is worrying me that it'll lead to a problem down the road. Right now it doesn't affect driving what so ever and nobody notices is either. Can anybody help me on how to fix it or how this happened? I think my car is out of warranty too....(its an 09 with 18k miles) or is it?\ both pictures were taken at equal distance and at equal zoom. |
11-20-2011, 02:42 PM | #3 |
135
Rep 3,293
11-20-2011, 03:49 PM | #4 |
62
Rep 167
11-20-2011, 03:52 PM | #5 |
Happy Camper
613
Rep 7,869
Drives: C63 AMG & 280 SL on Weekends :
Garage List 1969 Restored Merce ... [7.50]
2011 M3 Coupe TRADED [7.34] 1987 BMW 535is [1.00] Cars from the Past [6.50] The ///M3 Engine S65 [9.59] |
take your car in and have the camber checked to specification and adjusted. Do it soon or your tire will wear unevenly as you know. Good luck.
Cheers, Rolf-Dieter
Life will take us to some interesting places, fortunately The ///M3 will too with a many of us know this very well, now my C6.3 AMG with 487 HP does it too ---> Click here for some good stuff I found |
11-20-2011, 04:42 PM | #7 |
88
Rep 1,105
Looks fine to me if you adjust for the slightly different camara angle between the two. Look at the right pictures which is a tad more centered behind the wheel and the left which is just a bit more to the outside of the tire for the pic.
Looks about right to me. Lots of negative camber on our cars |
11-20-2011, 04:44 PM | #8 | |
135
Rep 3,293
Why don't you take ONE picture OP of the rear of the car and show us? Don't understand the reasoning behind 2 shots. Also, make sure you post up pics of the 359's once you get 'em. |
11-20-2011, 04:45 PM | #9 |
1904
Rep 5,678
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
11-20-2011, 07:11 PM | #12 |
11817
Rep 23,187
FYI the phrase is low and behold or lo and behold not long behold.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
11-20-2011, 07:15 PM | #13 | |
62
Rep 167
look at the cases of water to the right of the bent wheel. They're upright but the tire is not. Going to take it in the BMW Northwest on Thursday and Friday. |
11-20-2011, 11:39 PM | #15 |
140
Rep 309
can you get an "angle" gauge like they use in carpentry(shaped like a large "L") and place it next to the wheels?
I have a big one (12 inches on one side and 36 on the other) and use it to check my camber for a rough estimate. Your floor has to be flat, so check it with a level. If it is off by 4 or 5 degrees, i would be concerned and get it to the dealer. Somethin' is bent! |
11-20-2011, 11:41 PM | #16 | |
gotAWD?
Rep 55
CornFedEvo
11-21-2011, 01:47 AM | #17 |
892
Rep 9,032
OP: PLEASE STOP CALLING IT "BENT!"
It's called negative camber, like other's have said. Like the "troll" said, go get an alignement. If they can't align to spec, then SOMETHING is bent. I click here expecting to see a bent wheel, but instead get negative camber. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
11-21-2011, 01:28 PM | #19 |
141
Rep 5,264
Drives: 2008 E90M3
- Jason P
:Have: 08 E90M3, Varis VRS Front Lip, LS3, ESS Supercharger, Arqray Exhaust, Neez Wheels :Want: VRS Carbon GT Wing & Cooling Bonnet, LCI Taillights :Videos: EnvyRidesTV, GPR 1, GPR 2, GPR 3, ///MFEST |
11-21-2011, 01:30 PM | #20 | |
268
Rep 1,883
Drives: 2011 E92 M3
Sorry, just saying.
'11 BMW E92 ///M3 - ZCP and DCT
'15 Ford F-250 - Lariat, 6.7 Powerstroke Turbo-diesel |
11-21-2011, 02:02 PM | #22 |
BimmerPost Supporting Vendor
9587
Rep 10,878
If you take the car to an alignment shop, you can post the measured specs here and I may be able to tell you whether something is physically wrong or if you just needed an alignment.
The camber adjusters on the rear suspension use an eccentric bolt as seen here: The spring support arm is used to adjust camber (part number 4 in that diagram). The eccentric bolt on the inside is rotated about it's axis to space the arm further in or out depending on if less or more camber is needed. It's not unheard of for the eccentric bolt to slip in it's place from hitting a hard bump and lose it's camber setting.
