11-11-2011, 11:13 AM | #1 |
86
Rep 847
3rd Stop Light (Trunk) is Dead
I just went to get my annual MA inspection and found out the 3rd light is dead. I had the cracked lens problem last year and they wouldn't certify the car with a cracked lens so I changed the light. Then a few months ago the light bulb warning on the dash lit up. I checked all the lights and everything was working and the warning turned off after a few mins. Now the light is totally out and no dash lights either.
This is what I've done so far: bought one of those LED strips off ebay to check the wiring. Not sure if it's supposed to work but when I connect it to the wiring it doesn't light up either. This is the one I got: http://www.ebay.com/itm/Brilliant-Re...ht_3278wt_1163 Right now nothing is connected to the wiring but the dash warning light is still not on. Shouldn't it come on if the lights are disconnected? Any ideas? |
11-11-2011, 11:15 AM | #2 |
485
Rep 10,309
Drives: A///MERICAN!!!
Not sure, but try using CHMSL (center high mounted stop lamp) as a search term. It's a ridiculous acronym for a simple thing, but it may give you better search results.
