11-07-2011, 02:45 PM | #1 |
2289
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Seat Positioning Go Any Lower?
I like to position the seat upright for trackdays but I then find I have barely enough space to get my helmet on. I have the seats set to the lowest height possible and I'm not the tallest guy either (5'9"). Anyone else have this issue? I could've swore there was a trick to get them lower, maybe removing some washers?
11-07-2011, 02:57 PM | #2 |
CarbonFiber Engineer @ ZeroMassMotorsports
40
Rep 1,481
Dubb....I can't remember if it is the manual or powered seats which drop the lowest....but I thought it was the powered ?
I know for me....the only way I could sit deeper down was to lose 10 lbs in my butt. Worked for me. |
11-07-2011, 03:04 PM | #3 |
2289
Rep 12,565
I have the powered "m" seats. I suppose I can lose a few pounds lol.
11-07-2011, 03:05 PM | #4 |
24
Rep 784
Drives: 2011.5 E90 M3
I was about to post but then I realized I do autocrosses with the top down.
11-07-2011, 03:26 PM | #5 |
Rep 273
I've got heated manual 'M' seats in mine. I normally have them quite far back, and I know if you move them 'down' with them set too far back, they will not go fully down. I found that out when I bought the car, and noticed the passenger seat was lower than mine when I had it fully down. Moved it forward slightly and tried again - it dropped a LOT!
I'm 6'2", and I've got a lot of headroom with the roadster top up, and the seat fully down. Maybe try moving it forward a bit and see if you can get any more depth out of it ... |
11-07-2011, 05:40 PM | #7 |
485
Rep 10,309
Drives: A///MERICAN!!!
Took some pics of a heated/powered msport seat from a 3.0si coupe. To me it doesn't look like it can be modified to go lower, but here they are anyway:
Resized to 1024x768 for better viewing, I can email you the original sizes if you want more resolution |
11-07-2011, 07:33 PM | #8 |
150
Rep 688
I agree with West, I am 6'2" and easily have 1 1/2" above my head to the headliner even with my helmet on.
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor |
11-07-2011, 08:43 PM | #9 | |
Rep 273
If at 6'2" my Texas compatriot and I can fit in the car with ample headroom, it's hard to see not fitting with 5 inches less height - though some people have a longer trunk than others. But I've also never put the seatback upright while occupied, as I can't stand driving in that position. |
11-07-2011, 09:09 PM | #10 | |
2289
Rep 12,565
11-09-2011, 06:25 PM | #11 |
20
Rep 250
In my Z3 M Coupe, I took the seat out and removed the carpet and sound proofing that was squeezed between the seat mounts and the car body....every little bit helps.
11-09-2011, 06:27 PM | #12 |
instagram 997turbotom
279
Rep 7,377
In a coupe, I don't see why you should have helmet clearing issues at 5'9
roadster and the rollbars is a different issue
11-09-2011, 06:35 PM | #13 |
2289
Rep 12,565
Like I said, I have the seat literally upright, 90 degrees. I'm not making it up!
11-09-2011, 06:40 PM | #14 |
279
Rep 7,377
I missed the detail about sitting upright, I recommend removing the oem sliders and motors, and fabricating simple to bolt up to the floor
