TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      09-29-2011, 12:17 PM   #1
Tmac
13
Drives: 14 M5
Coming up on 6 weeks in the shop
My check engine light came on my 09 50i
Cause was a hose was cracked due to the heat from the turbos and was screwing up the air/fuel ratio.
This led to a high build up of carbon which BMW determined they needed to clean out.
So they had to pull the engine, do some disassembly and clean it.
With parts backordered, my X6 was in their shop for 5 weeks.
I picked it up, got 10 minutes away and the light came back on. Turns out it is still reading that the air/fuel ratio is off.
It will be 6 weeks tomorrow w/o my X6.
Is there a point when BMW says, it is too expensive to fix this problem, here's your money back? I cant see it being cheap to pull the engine, but to go back to work on it after all that they've done, that must get pretty pricey. And it sucks driving a 323 in place of my X6, although the seats are comfortable.
      09-29-2011, 12:39 PM   #2
AndyzDad
Drives: 335i E92
You should notify BMW Canada for this and have them look into the matter, 6 weeks for a car is way too long. Good luck.
      09-29-2011, 01:06 PM   #3
Mike van D
Mike van D's Avatar
Germany
18
Drives: SG X6 35i; MW e92 M3
Best of luck with this situation. Hopefully they can work it out. Not sure on how much they would spend on trying to fix it. Agree with the above...would contact corporate to see if they can give you more info.
...just enjoying life.
      10-07-2011, 05:40 PM   #4
Tmac
13
Drives: 14 M5
Well they called last Fri and thought they had solved the issue by replacing both turbos. They did that Mon-Tues, kept car for test drives, and... issue still exists. 7 weeks now. I tried calling BMW today but they close early on Friday, so I'll have to try them on Monday.
      10-08-2011, 10:54 AM   #5
longisland85
Drives: 2012 x6 50
my x6 was in the shop for 30 days and they told me pick out a diff car now i have the x6m
      10-09-2011, 06:44 AM   #6
CIWS
Moon Parasite
CIWS's Avatar
655
Drives: F98 X4M Competition
Do you know what code it was throwing when the CEL was on ?
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged
      10-11-2011, 12:05 AM   #7
Tmac
13
Drives: 14 M5
I dont, looking at the paperwork it mentions RO 162954, would that be it, or something completely different?
      10-11-2011, 12:08 AM   #8
Tmac
13
Drives: 14 M5
What was it in for? Was it the dealership, or did BMWNA make the call for you to get another one?
