09-18-2011, 01:36 PM | #1 |
560
Rep 570
Brake Review - 1 Day DE at NHMS - Stock w/Cool carbon Pads
I ran my E90 ZCP at NHMS w/the Porsche Northeast Region on Friday. The car is stock w/only a pad updgrade (Cool Carbon pads) and ATE Blue brake fluid. Tires are the Conti SC3.
I am a beginner/novice w/the PCA, just to give an idea on ability, so I'm not too hard on the brakes. The Cool Carbons were bedded per their recommendations (excellent pad transfer to rotors) and brake fluid was changed two days before the event. The pads have been nice and quiet, although I'm a stickler for good caliper surface lube and they have shims, so they only groan slightly when really hot when coming to a slow stop. At the track, the pad offered good bite and fade resistance. The hard braking toward turn 3...felt I should get better deceleration, but still not too bad. By the end of the day, the pad material transfer still uniform and not excessive. Factory rotors seemed to manage heat well, w/the aluminum pins and aluminum rotor hats. Wheels barely got hot. Pedal got soft for the last session, which I attribute to my hottest (fastest) session and boiling the fluid. Pedal is still soft, so going to bleed/switch fluid in the next day or two. Pads held up well, had good track performance, and I think I may look into Castrol SRF fluid, as the porsche guys all have good luck w/this fluid and a higher boiling point than ATE Blue/Gold. It was an ambient cool (temp) day, though, so managing heat w/the brakes seemed easy. Feedback welcomed. -Brian |
09-18-2011, 01:41 PM | #2 |
11817
Rep 23,187
I'm surprised your wheels didn't get hot. It was impossible for me to get a pressure on mine without gloves as the radiant heat off both my wheels and brakes was extremely hot. This was on a mid 60s day and I am pretty new on the track as well.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
09-19-2011, 01:05 AM | #4 |
chris
278
Rep 12,144
no point doing SRF fluid... your pads will probably fade first before the need to go SRF... cool carbons are not track pads, ATE will be sufficient.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
09-19-2011, 08:20 AM | #5 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
My cost/benefit analysis says that Motul RBF600 is cheaper in the long run and just as good.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
09-19-2011, 08:22 AM | #6 |
560
Rep 570
I realize Cool Carbons aren't track pads. They're a dual-use pad, as confirmed last Friday and figured I'd provide feedback. The SRF fluid would be beneficial in that I wouldn't have to flush it as frequently. The ATE Blue boiled and introduced air this time around, so no choice but to flush after every event.
09-19-2011, 08:35 AM | #7 |
15
Rep 751
You might want to try some more aggressive track pads. The additional efficiency when hot may help manage your fluid temperature. The only pad I have ever used that I would consider a marginal dual purpose pad, is the StopTech high performance street pad. I believe they are made in OE M3 caliper sizes. But I should add, my only experience with them has been with the StopTech system. The differences in pad surface area, and rotor design might not allow a valid assumption as to how well they would work with the OE calipers.
09-19-2011, 09:09 AM | #8 | |
169
Rep 3,831
I use to use RBF600, great stuff, but I had to do one or two mid track season bleeds(I did not do the work myself), so with labour and extra fluid, in the long run cost me more. But this will def depend on how often you hit the track.
09-19-2011, 09:29 AM | #9 |
Rep 134
I had Ferdo DS2500's put on when my car came in at PDI. Also added Stainless Lines and Motul RBF600. They were very noisy until I got them bedded in. Now they are extremely quiet and have a quite a good cold bite for being a mostly track pad.
Car is almost broken in and my track date is set for next Thursday. I figure if I fry them out there I've done all I can with the stocks and will be forced to go with a big brake kit. Hoping I don't have to do that, but the stock brakes are just not meant for anything other than street duty. What a shame BMW decided to cut cost and use such an inferior brake system and then not give it any ducting to try and cool them down. |
09-19-2011, 10:55 AM | #10 | |
1571
Rep 8,076
Actually, I've found that Motul will last for 3 days but since I am now doing weekends...paying labor for a mid-weekend bleed does favor SRF. I guess if you pay someone to bleed the brakes (definitely not a bad idea)...SRF makes a lot more sense.
09-19-2011, 11:08 AM | #11 |
11817
Rep 23,187
why are you needing to bleed the brakes so much more often with the race fluid? sorry for the newb question. was looking at doing stainless lines and better fluid so curiuos what to go with.
09-19-2011, 11:29 AM | #12 | |
560
Rep 570
Keep the feedback coming. I have a second HPDE in Oct and will have more info. -Brian |
09-19-2011, 11:42 AM | #13 |
BimmerPost Supporting Vendor
548
Rep 5,695
Thanks for your review, glad you had a great time out at the track! The Cool Carbon pads did well for us out at the track as well these past few events
09-19-2011, 12:09 PM | #14 | |
Rep 134
To OP, let us know if you switch brake fluid, pads, or both. It's always interesting to see what everybody's experiences are. -Chris |
09-19-2011, 01:14 PM | #15 | |
69
Rep 957
To OP - you should not be boiling the fluid if you can still run with these lower-temp pads. Are you doing a cool-down lap? One way to boil fluid is to come in very hot and park the car - this way you eliminate air flow and red-hot disks heat up everything around them, including the fluid in calipers. Another point is that Castrol SRF is not going to be a big difference in terms of dry boiling temp either - if you are boiling fresh ATE (536F boiling point) Castrol with it's 590F bp is not changing things much. Where it does change things is how long it stays close to it's dry boiling point - while ATE's bp would likely degrade to high 300s F within months, Castrol's is likely to stay above 500F for the whole season. But if you are boiling fresh ATE, you are likely to boil fresh Castrol as well, so it's longevity would not be a big benefit, as you'll have to flush anyway. |
09-19-2011, 05:24 PM | #16 |
548
Rep 5,695
We noticed also that the wheels don’t seem to get as hot during track events with the Cool Carbon pads. Cool Carbon attributes this to one of the several fiber types they use which is a hollow ceramic fiber that channels away heat quite effectively. Heat capability is noted as exceeding 600C (1112F), but we think it goes higher. Castrol SRF and Motul RBF600 are both excellent choices to consider and the economics can help determine best choice. AP Racing also offers some excellent brake fluids. As mentioned in other threads, the Cool Carbons are not a dedicated track pad but rather a very capable combination pad that can handle some track usage especially when combined with good brake management.
Any good BBK set up should dissipate heat better than BMW stock calipers and rotors and this should increase fade resistance. We have had very good luck using CC pads with BBK kits from both BMW performance and also other popular brands of BBK’s for which CC pads are available. |
09-20-2011, 06:04 AM | #17 | |
1571
Rep 8,076
09-20-2011, 09:39 PM | #18 |
Rep 63
Drives: M3s
Garage List 2012 BMW X5 [0.00]
2001 Ford Excursion [0.00] 1995 BMW M3 [0.00] 1995 BMW M3 [0.00] 2005 BMW M3 [0.00] 2004 BMW M3 [0.00] 1990 BMW M3 [0.00] 2008 BMW M3 [0.00] |
***shameless plug***
I've a set for sale if anyone is interested.... http://www.m3post.com/forums/showthread.php?t=587685
IP #19
GTS3 #72 |
09-21-2011, 06:26 PM | #19 | |
548
Rep 5,695
09-23-2011, 10:45 PM | #20 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
09-25-2011, 10:42 AM | #21 |
11817
Rep 23,187
im still sort of confused on this one. i want to run stoptech or cool carbon pads on stock rotors and will installing stainless lines and higher temp fluid as well as a 3 inch duct system to the backing plates. which fluid should be used? am i going to need to bleed every other track day as some indicate? i experience some fade at the end of sessions but dont think i have boiled fluid.
09-25-2011, 12:47 PM | #22 |
1571
Rep 8,076
Depends. Sometimes the pedal will go a little soft but my brakes feel good after things cool down.
Other times, the pedal feels spongy even after the brakes cool...then I bleed.
