09-05-2011, 07:33 AM | #1 |
148
Rep 2,278
AST 5200 Grand Am series
This is my third suspension modification. I started out with H&R springs. I liked the new look but not the ride or performance. After riding in a fellow forum member's car with the Ground Control kit that retains EDC, I decided to go that direction. That was a real improvement and I was happy. But I knew that could not be the ideal setup even though it works very well. I found I did not use EDC anyway and always had it on the most aggressive setting which seemed to handle the 440lb front and 600lb rear springs best.
So I decided to try something new and found that there were not a lot of choices if one wanted an out of the box fully integrated kit. So I ended up with a setup that was not out of the box. I bought the suspension from Bruce at BRRacing. The springs are Swift and the rate is roughly 500 lbs front 800 lbs rear. There have been a few hiccups along the way but in the end everything worked out. They had to machine the lower rear shock mount; the upper rear shock mount came from Turner. The Vorshlag camber plates had to be modified to fit the Grand Am shocks. I ended up using the rear spring mount adjuster from my Ground Control kit as I didn't have the stock one with me at the time. Installation was done by my friend Noah at Cohesive Garage in West Seattle. He did a great job but it wasn't easy and it struck me this was car surgery! It was a bit tricky running the hoses for the remote dampers as they needed to go under the fender liners. The other AST 5 series I have seen have the hoses in front come off the top of the Vorshlag camber plates so the installation of the canisters in the engine bay is easy. But the Grand Am spec ones come off below the camber plate. So now that they are on and I have done one track day so what do I think? I really love this setup. As a preliminary track setup I have it set 9 clicks from the softest setting on both compression and rebound. This is more comfortable than either the H&R or the Ground Control setup. You feel the bumps but the dampers take the harshness out of it. And the car sets perfectly in the turns and there is just a feeling of being in complete control. My installer Noah is an instructor for Alfa and has a history on track with my car and he was very favorably impressed. I do not time at the track but I am in the A run group and at the PCA event a Pacific Raceways Saturday was very competitive with a GT3 driven by an instructor. A friend who does time was behind me and gave me his lap time which I'm pretty sure is about 2 seconds faster than I drove last time out. I had to take a fair amount of air out of my tires as my tire temps went up significantly from last time out 10 days ago. I'm not an expert and this is just my personal impression. JAJ was at the track Saturday and he knows the technical side. All I know is this feels better and I think I am significantly faster through the turns. One of the reasons I wanted this suspension is I have a friend with a modded 330 with AST 4100s and he is super fast and that car is so composed. Not interested in discussing prices - contact vendors.
2015 f80 M3, 2016 GT3
09-05-2011, 11:25 AM | #2 |
892
Rep 9,032
I thought Harold had AST kits that are ready for install?
How's the Grand Am kit different from the other 5 series dampers? Nice write-up and pics.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
09-05-2011, 12:14 PM | #3 |
80
Rep 961
As dawgdog said, I was there to see this setup on its first time out, and from watching the car through a couple of fast corners with some major bumps, it looks very composed. These high-end double adjustable setups have that strange ability to control the body motion so that with the right settings, the ride gets smoother and the grip gets higher all at the same time.
Great write up - well done! |
09-05-2011, 12:37 PM | #4 |
141
Rep 5,264
Drives: 2008 E90M3
these look seexy...
- Jason P
:Have: 08 E90M3, Varis VRS Front Lip, LS3, ESS Supercharger, Arqray Exhaust, Neez Wheels :Want: VRS Carbon GT Wing & Cooling Bonnet, LCI Taillights :Videos: EnvyRidesTV, GPR 1, GPR 2, GPR 3, ///MFEST |
09-05-2011, 04:38 PM | #5 |
169
Rep 3,831
Congrats on the set up. Looking forward to getting more feedback.
What alignment settings and ride height did you go with? Are they 9" springs? Do they make the AST 5100s for our application?
09-05-2011, 05:53 PM | #6 | ||
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
I hope the rear shock towers were reinforced...How well the stock rear shock towers take the racing type eye to eye damper with bearing ends is unknown.
Yes, AST 5100 is available. Last edited by HP Autosport; 09-05-2011 at 06:06 PM.. |
09-05-2011, 06:03 PM | #7 |
chris
278
Rep 12,144
just curious, what did you use to get rid of the EDC codes that would come up since you dont have edc shocks anymore ? did someone coded them out for you?
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
09-05-2011, 06:07 PM | #8 |
3847
Rep 54,376
Drives: F80 M3
09-05-2011, 06:50 PM | #9 |
108
Rep 697
Very nice! I've been officially "one upped". I've had my AST's for almost a year now and am still super happy with them. Mine are not quite as impressive as those Grand-Am series though. You made the right choice with Bruce and crew at BRracing.
Did you get the digressive valving package? |
09-05-2011, 06:52 PM | #10 | |
169
Rep 3,831
09-05-2011, 10:13 PM | #11 |
80
Rep 961
Unless you're running a high downforce Prototype car, digressive valving would be normal for this kind of setup. Otherwise it will ride like a buckboard.
For STALKER's benefit, the digressive damping curve has less damping as the speed of shock motion increases. "Progressive" would mean damper rate increases at higher speeds, and is the opposite of "digressive". High speed damping is set to absorb bumps in the track, and should be softer than low speed damping, which is set to control body motion when the driver is braking or turning. Last edited by JAJ; 09-05-2011 at 10:21 PM.. |
09-05-2011, 10:15 PM | #12 |
80
Rep 961
The dampers are still just dampers - they don't have springs on them, so there's no need to reinforce the rear shock towers.
It's the subframe mounts that are taking more abuse with the higher rate springs - if there could be problems, that's where it will be. |
09-05-2011, 11:06 PM | #13 |
23
Rep 194
For all to note....the new AST Grand-Am sets are slightly upgraded versions of the AST 5xxx series. Most in the series are running the 5200, so these sets are more readily available, along w the parts. Turner has also been running these sets on some of their BMW Grand-Am cars, so there is more info available on the setups and implementations....although, most are all done on "pure" racecars, not track combo cars. The kits can be made to work, and offer some other advantages....by being a pure "eye to eye" setup, they are easier to pull and replace, so if a spring rate change is needed or desired, you can now do that without the hassle of undoing the upper camber plate and remote resv....you simply pull the eye bolts, and presto....you have your shock out, and even on the front strut, you can undo the front strut body and take off the springs. The rears in this case are true "coil-overs".
Unlike a street setup, we changed the length of the springs in the front, and also added another sweet little trick to ensure no spring bind during normal turning or parking lot travel. Great write - up Carl....have fun, you have a GREAT car to play with. Bruce BRracing |
09-05-2011, 11:57 PM | #15 | |
3847
Rep 54,376
Drives: F80 M3
Time will tell. Dampers are just dampers and many E36/E46 shock towers fail in the past without going to a coilover type setup. |
09-06-2011, 07:26 AM | #16 | |
148
Rep 2,278
Not sure that AST makes the 5100 in the Grand Am series but the 5100 would be a very nice setup indeed. Probably all I needed. I'll message you my alignment setting when I get them out of my glovebox.
09-06-2011, 09:00 AM | #17 | |
169
Rep 3,831
09-06-2011, 10:55 AM | #18 |
3847
Rep 54,376
Drives: F80 M3
09-06-2011, 02:34 PM | #19 | |
108
Rep 697
09-06-2011, 03:45 PM | #20 |
80
Rep 961
I had a look at their Facebook page and found a graph comparing two different digressive pistons, a new one with a really sharp blowoff knee and an older one with a softer knee. Is that the diagram you're talking about?
09-07-2011, 11:15 PM | #22 |
148
Rep 2,278
No, they are not. And the ride is incredible. I dialed down the compression by two clicks and upped the rebound by one. So I am 3 clicks from full compression and 2 from full rebound. I drove today on a route where I was jarred by the H& R and the Ground Control and it was so composed. Can't wait to try this setting on the track Friday.
This is my best mod yet, by far. Like having a new car.
