09-03-2011, 09:04 PM | #1 |
43
Rep 476
How to check which sideband sensor is for front vs rear bank?
EDIT: Sorry for the mistake in the title guys, it drives me absolutely nuts that Mac OS X auto-corrects "wideband" to "sideband" without asking--and the forum won't let me edit it.
I'm in the middle of the header swap now and am not sure I understand the marking I made to keep the sensors straight. I was much more careful the first time I did the swap... How can I be certain which wideband sensor is for the front bank and which is for the rear? They lead to two connectors to the top left of the coils (viewing from the exhaust side)--is the top one the Front bank or the Rear bank? I searched both the forum and the web and can't find anything but "don't mix up the ordering". Great. Last edited by iPhoneEngineer; 09-03-2011 at 10:41 PM.. |
09-07-2011, 12:51 PM | #2 |
76
Rep 987
http://imageshack.us/f/263/s54o2sens...ectorsgw8.png/
Kinda late for you but this is the diagram I found. It has been a while since I did the swap so I can't 100% vouch for the diagram. Last edited by Jumbosock; 09-07-2011 at 05:07 PM.. |
09-07-2011, 01:00 PM | #3 |
43
Rep 476
Fantastic, that's exactly what I was hoping for! I seriously couldn't find any such diagram, anywhere.
I intend to pull off the air pump and heat shield again to re-torque the header bolts now that they have heat cycled a few times, do a final check of the O2 wiring, and also fully torque down the sensors. I have another obligation tonight but this will happen by Thursday night. If anyone else can confirm that the front header's wideband plugs into the furthest "up", "left" sensor harness on the valve cover, that would be great . |
09-07-2011, 04:48 PM | #5 |
instagram 997turbotom
286
Rep 7,377
crap, i wish I had time to find the info I used. search for e46 m3 header install threads. I used pelicanparts.com to confirm part numbers on the sensors to see which ones go where
I don't want to guess anything and tell you the wrong info.
09-10-2011, 12:09 PM | #6 |
43
Rep 476
So I checked out the harnesses and there is NO apparent difference between them; one can plug into the other. I also rechecked codes and don't have any new ones after a week of driving, so I assume that the sensor positions must be correct or the car would have complained by now... Still surprised it is this difficult to get information on the wiring.
Only slightly off topic--can anyone recommend a good service manual? Is there a P/N to order a BMW one from one of the online parts dealers? |
