      08-02-2011, 12:36 PM   #1
KIYO
Austria
23
Drives: 1er M Coupé
1M fuse box behind the glove box
I thought this might be handy.
The actual fuse layout might be different depending of your options.
I took terminal 15 positive (which is on while the ignition is on) from fuse 9 which was empty in my 1M in order to hide the cable of Garmin portable navigation.
The T-30 bolt in the arrow can be used as an earth point (terminal 31).
      08-02-2011, 12:41 PM   #2
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
thanks
      08-28-2016, 02:05 PM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10637
Drives: N54 e82
I just spent the last hour looking for a +12v key on, fuse source. I can't believe its so hard to find an open slot. All of my "normal" sized fuses were hot all the time. Only those tiny small fuses were switched +12, #15 power - but I still couldn't find an open/available empty slot.
I migt have to buy a micro piggy fuse box link from Amazon.
      08-28-2016, 03:10 PM   #4
dbronnik
dbronnik's Avatar
223
Drives: N54 E88
I can confirm you will need a micro fuse tap.
Appreciate 2
Dackelone10636.50
croy0.00
      08-28-2016, 04:00 PM   #5
Dackelone
European Editor
Dackelone's Avatar
Germany
10637
Drives: N54 e82
Thx. Where did you tap into for the ground ? That same torx screw ?
I believe those really small fuses are called: Mirco2 fuses. So I plan on ordering one of these fuse piggy back thingys....
https://www.amazon.com/gp/product/B0...A3TOPXSF99I2AT
      08-28-2016, 10:26 PM   #6
dbronnik
dbronnik's Avatar
223
Drives: N54 E88
Yep, that torx screw for the ground -- that was the only annoying part of the install
I'm still hooked into a medium size fuse (all I had laying around) that not switched, but I think you might need a mini apm/atm (https://www.amazon.com/gp/product/B00K17M2IU/) rather than an atr micro2 (can't confirm for sure!)
1addicts
