08-02-2011, 02:08 AM | #1 |
Rep 35
215/40-18 in the rear?
Absolute tire newbie, browsed around and after looking through various threads, I was wondering why this isn't feasible/done. It seems like the people running on the 17s are running off of 225/45, so why isn't this combination done?
08-02-2011, 01:30 PM | #4 |
Rep 35
I'd prefer more neutral handling + the added benefit of being able to rotate the tires all around. Ah, the torque would be an issue?
08-02-2011, 02:01 PM | #5 |
Rep 40
Have you ever put the accelerator pedal to the floor in your car? These cars make good torque, even factory stock, and are plagued with traction issues. I couldn't even imagine running a 215 in the back! My car spins them in 3rd gear with the factory run flats!!
08-02-2011, 02:58 PM | #6 |
General
2048
Rep 25,989
215's are quite a narrow tire for a 135i to be running in the rear. Like everyone has said, the stock sizes already deem to be difficult to have the rear end stick under acceleration.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
08-03-2011, 01:31 AM | #7 |
Rep 35
Something must be wrong with my car (or me) then as I've never really seem to have traction issues. It's just so... fluid. It doesn't feel like a forced induction car as power delivery is just so incredibly linear, perhaps even boringly so. But I've never really gunned it below 2nd and I've done quite a few spirited runs before and haven't had traction break besides on bumpy roads.
08-03-2011, 02:46 AM | #10 |
Cone Cruncher
31
Rep 534
I'm very concerned for you. With the 135i... you should be burning through 245 rears, no problem.
If you are contemplating a square setup for tire rotation, it's not really going to save you a lot on the wear. Your fronts will wear off the edges (due to a lack of negative camber) and the rears will wear evenly. It's actually easier to just wear out the fronts and replace 2 tires at a time in my experience. The other problem is that you're going the wrong way. Wider tires = more ability to grip in corners and general higher stability. Skinnier tires will decrease lateral grip and the car will feel more "wobbly" under normal driving circumstances. In my experience, I tried to fix the understeer issue with going slightly wider in the front to 225 / 245 setup. Unfortunately for me I picked the wrong tires (continental DW) and it felt mushy and the understeer was just as bad as with 215/245 run flats. When I realized that the correct way to fix the problem and even out tire wear was to add negative camber in the front and go with wider tires all around, everything became much much better. So my advice (and why 215 square isn't done): - If you're looking to increase tire life, add negative camber - If you're looking to fix understeer, add negative camber - If it's time for performance, add negative camber + add the widest tires possible - Stock fenders: 255/275 - Wide body kit: 275 square (maybe wider in front depending on kit) - Widest square with a stock suspension: 235/40-18s |
08-03-2011, 03:59 AM | #11 | |
64
Rep 760
Drives: E82 135i & F80 M3
Even in second gear, it feels like car with the stock run flats cant break traction. No blinking light if its dry out. |
08-03-2011, 05:32 AM | #12 | ||
37
Rep 2,084
Do you track or autocross your car? When are you experiencing non-neutral handling? ...adding: Oh, I see. Quote:
08-03-2011, 07:54 AM | #13 |
Resident Kerbalnaut
477
Rep 10,703
I currently run a 245 square setup and for the most parts its perfect.
Tires last longer because when you rotate you change the forces applied to the tires. This realigns the rubber molecules so that when you rotate again the rubber is more resistant to the striations that cause the tire to wear. For example, my sister and I both have SVT H/O 302 2000 Mountaineers. I rotate and she doesn't. We have a similar driving style. Her tires lasted 35,000 miles. My tires lasted 80,000. I front back rotated every 3K miles. It's as simple as that. |
08-03-2011, 08:39 AM | #14 |
37
Rep 2,084
^^ As simple as that? I'm pretty sure you omitted to mention either new wheels or camber plates or fender rolling to fit 245s in front. I'd be surprised if spending money like that to extend tire life would actually add up to a significant savings for the OP.
08-03-2011, 09:13 AM | #15 |
Resident Kerbalnaut
477
Rep 10,703
I said as simple as that to the extended life of the tires through rotation
And no I shelled out 2 grand for a set of OZ wheels and star specs, no fender rolling no plates. It made sense to me as i cracked and bent my stockers and needed new wheels and tires anyway. |
08-03-2011, 10:30 AM | #16 | |
124
Rep 5,627
Tom |
08-03-2011, 10:53 AM | #17 | |
winter mode
62
Rep 2,057
Drives: 08 135i, 88 M3
is that molecular alignment thing for real? i know the whole directional thing makes a difference in sharpening skis, tho not at such a minute level
88 M3: BMWCCA J Sport
08 135: because streetcar |
08-03-2011, 11:34 AM | #18 |
Resident Kerbalnaut
477
Rep 10,703
It makes sense when you see it in pictures...Its hard to paint a good picture with words.
Pretend these are the wear patterns of tires -- -- <- Thats a front tire (main forces left right) -- -- | | <- thats a rear one (main forces front rear) | | By doing a front back rotate the forces that caused the above wear patterns are no longer acting in conjunction with way the tires have worn (ie the direction of the weakened molecular bonds between rubber molecules) So the tires are more resistant to wearing. Over some time the molecules realign themselves to their new wear pattern as surface rubber wears off, thats when you rotate again. Its a whole big thing that has to do with molecular geometry and force vectors, but it is real. Thats the simple explanation, make anymore sense? |
08-03-2011, 11:59 AM | #19 |
111
Rep 1,338
with symmetrical directional tires, they can be flipped as well, which even further increases tire life. this makes a HUGE difference, especially in camber-impaired cars.
08-03-2011, 04:04 PM | #20 | |
64
Rep 760
Is something wrong with my car? I want to dyno now... |
08-05-2011, 03:26 AM | #21 |
Rep 35
08-05-2011, 09:22 AM | #22 |
Resident Kerbalnaut
477
Rep 10,703
I'm on a set of 17x8 et 40 OZ Ultraleggeras with 245/40 star specs all around
