07-27-2011, 06:43 PM | #1 |
Rep 31
Shopping for X5M - questions
I am considering returning to a BMW family after an 8-yr break and looking at X5M. I have a few questions:
1. Why is there a spare tire option if the vehicle comes with run-flat tires? 2. Is there a way to order the vehicle with all-season tires instead of summer tires? If so, does it cost extra? 3. I see members here ordering various BMW wheels with their vehicle. Where can I see the entire selection? |
07-27-2011, 09:27 PM | #2 |
Rep 23
-runflats only last so long "flat" or perhaps long distance travel.. i had a tire blow out and only make it about 20 miles, i believe they are good for "200"
-you would have to ask your dealer, i didnt have that option for mine. there is a winter set of tires and rims for the x5m ( about 4k and order before you see snow!) - grab a bmw x5 accessories catalog at your dealer or build one online.
-2011 BMW X5 M
-2003 BMW X5 4.6is -2005 srt10 Dodge Viper, 2010 MV Agusta F4 |
07-27-2011, 09:33 PM | #3 |
Rep 23
get the comfort seats! far better than the sports (ive had both)
-2011 BMW X5 M
07-27-2011, 11:21 PM | #4 |
44
Rep 567
Yes the active ventilated ones.
Also purchase 22" aftermarket wheels for this beast. 21" seem smallish. The summers on the 20" are ok, forget all seasons if you are driving on the track or aggressively
| '10 Escalade ESV | '12 Audi S4 | '01 Audi S4 | '15 328d Xdrive M-Sportwagon |
07-28-2011, 06:37 AM | #5 |
Rep 123
X5M
This a dealer option ($150 for the tire only - still need a jack). The well is already there - just empty. I plan to replace the RFT's with conventional's when they wear out. They're a harsh ride, and a potentially expensive one if you actually get a flat (they are not repairable, due to liability considerations). 2. Is there a way to order the vehicle with all-season tires instead of summer tires? If so, does it cost extra? The dealers I spoke with would not entertain a change-out. When you buy the car, the OE tires are yours, and you can replace but you're stuck with the OE tires. Also, all-seasons in 20" low profile are still low profile, and really won't serve you well in the winter. The real solution to winter driving would be to get 19" wheels and tires for the winter. 3. I see members here ordering various BMW wheels with their vehicle. Where can I see the entire selection? Don't know why you'd want to switch - the BMW rims are nice (albeit a chore to keep clean)! |
07-28-2011, 09:25 AM | #6 | |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
2) On the regular X5's you can. I don't believe the //M X5's have that option. Just get another set of dedicated winter wheels and tires. I'd run 18's or 19's as your winter wheels. 3) It's in the BMW brochure if you want OEM BMW recommended ones. |
07-28-2011, 04:15 PM | #7 | |
300
Rep 808
07-29-2011, 06:07 AM | #8 | |
Rep 123
X5M Spare Tire
07-29-2011, 12:06 PM | #9 | |
300
Rep 808
the chepaest amount I have found is $155 for the tire from tire rack and $335 for the wheel from various dealers. You'll still need a lug wrench, jack and valve and valve stem then have the tire mounted. 36-12-0-418-846 Continental spare 155/80/19 36-11-6-775-450 Emergency wheel lightweight alloy. Really only trying to help you out as I have spent some time researching exactly what this is at what is needed. Most the dealers without the part numbers know nothing about it. |
07-29-2011, 12:38 PM | #10 |
173
Rep 901
spare
I made a mistake of not getting the spare tire option so had to pay $350 for the spare tire plus the jack.
07-30-2011, 02:55 AM | #11 |
Rep 130
I plan to switch to non run flat all season.
Continental and Nitto both have performance all seasons in the M size. That way, it reduces a ton of rotating mass. no need to swap wheels and tires for winter As far as the spare. I have a spare MB airpump that i will leave in the truck when the regular tires go on. It comes with a can of sealant.
08-07-2011, 08:15 PM | #12 | |
Rep 31
I was really wondering about other OEM BMW wheels, not aftermarket wheels. I am not really crazy about the stock X5 M wheels and if nothing else I would order them in gunmetal gray instead of silver. |
