07-06-2011, 04:56 PM | #1 |
1904
Rep 5,678
Jacking two side wheels at once?
To swap out wheels for HPDEs or winter, I have historically used the jacking points and lifted each corner independently to change the wheels one at a time. I don't particularly like the twisting action this does to the frame.
Rather than using the front/rear jack points, could you put the jack on the side of the car, in the center, and jack up the entire side of the car to lift both wheels on that side? Alternatively, I guess you could jack up the front, put a jack stand under the side and then jack the back. I know there are jack points in the back (some use the rear diff, others a different point) and similar things in the front but I can't reach them effectively. Any thoughts? Thanks!!
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
07-06-2011, 05:37 PM | #2 |
819
Rep 7,887
Never jack under the diff as you break the fins!I use the rear side jacking point to jack up the complete side of the car.Never had an issue doing it that way.You have to jack it up quite a way to get the front off the ground doing it this way.
07-06-2011, 05:45 PM | #3 |
1904
Rep 5,678
I guess the other option would be two jacks so you could lift the front and rear side jacking points at the same time. Come to think of it, I may actually invest in a second jack. I just hate seeing the car twist when only using one jacking point.
07-06-2011, 06:12 PM | #4 |
20
Rep 163
Heath, I use two floor jacks at the same time. Not sure why I started doing it this way, but it's quick and like you said, keeps the car level for each side.
2018 M4 MW/SO
2018 X3 M40i PB/CO 2005 M3 TiAg/BL |
07-06-2011, 06:32 PM | #5 |
258
Rep 5,012
I would never lift the car from the side to lift both wheels; even lifting just one produces unpleasant creaking. For that reason, when I remove a wheel that way, I quickly lower the car to a level stance until I'm ready to reinstall the wheel. And no, no middle side jacking point; only the ones next to each wheel.
Just lift the front and the back independently. I'd never put my car in 4 jack stands for safety reasons, but some folks do it. The most I do is one end on ramps (and wheels choked) and the other on jack stands. Oh, and I always use the differential to lift the rear and zero issues, but the trick is to place the basket right at the middle, below the brace, not the fins. And I always put the car in either ramps or jack stands right away. |
07-07-2011, 02:09 AM | #7 |
611
Rep 10,407
Donn't worry about any structural stress for corner jacking. You are very far from the yield strength of any part of the unibody. The engineers need to account for this along with hundreds or more subtle load conditions.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
07-07-2011, 10:43 AM | #8 |
201
Rep 4,318
I have started doing front and rear. Like was said above not on the diff fins but just ahead of that will be fine. For the front, drive up on some 2x10s to get access to the front central jacking point and lift from there.
GT3 RS | Desperately seeking the next great M car...
07-07-2011, 12:07 PM | #9 |
Commander-In-Chief
2196
Rep 8,944
True - whenever you drive at an angle down a driveway ramp you are effectively doing the same thing.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
07-13-2011, 01:11 AM | #10 |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
Heath, I kind of chuckled a bit when you asked this question and in the same sentence said it was for a HPDE event. There is no issue in using one jack to lift both wheels off of the car on one side, there is no where close to the forces put on the unibody from jacking that there would be from the driving you will be doing at Shubie on the HPDE. If the frame of your M3 was so delicate that it suffered damage from jacking one corner you would have more serious problems!!!!
Heath, in the future just put your jack under the front lifting point on the rocker panel and jack the car until both wheels on that side of the car are off of the ground, it works really well. *Never, Ever put the jack in the center of the car body or rocker panel since you will kink the panel, damage the paint/sealant, or both. Please only use the jack points to lift the car!!!! |
07-15-2011, 06:51 PM | #11 |
258
Rep 5,012
Indeed, but that doesn't mean the car likes it . Car is definitely not going to break in half, but that's how cars 'age' over time, developing creaks/rattles/moans/etc; you're expediting the process every time you hear it creak. It'd avoid twisting a car like that, but to each his own. Have a great weekend ahead gang.
07-15-2011, 11:34 PM | #12 |
68
Rep 869
Can you use front (or rear) jack point and lift one whole side, put 2 jack stands under, then jack up the other side the same way to end all-up on 4 jack stands? I am going to put new brake pads on and also do a brake fluid flush at the same time. I hear you need to flush all four calipers in a reasonably quick sequence to avoid mixing of old/new fluid. Doing 1 corner at a time would be too slow. Yes? No?
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
07-15-2011, 11:53 PM | #13 | |
4th down; 4th quarter? Renegade.
87
Rep 3,850
More nonsense from the worry-wart. Last edited by Singletrack; 07-16-2011 at 12:02 AM.. |
