06-28-2011, 08:58 PM | #1 |
Rep 5
Z4 pads and rotors
The brake pad sensor light went off on my 06' z4 3.0i. I called a few places to check the prices and the general quote was around $700+ for the front pads and rotors and almost same for the rear ($150 for brake fluid change). I never did a brake pad change before and have a mileage of around 35K miles.
The guy mentioned that it is a must to change the rotors with the pads for a z4. Is this true? Are the prices reasonable? Thanks in advance!! |
06-28-2011, 10:19 PM | #2 |
Dog Listener
707
Rep 7,850
"Must change the rotors with the pads...."
Uh, in one word, no. It's not required. The rotors need to be replaced if: A. They are too worn (thin) and out of specDid this "guy" actually measure the rotors or just say "gotta replace them"? If the later, I'd steer clear of that shop. I don't know offhand what the specs are for your 06 Si. Someone may chime in with it, or you can search this site and/or Google it. Or you can look on the rotor itself. I'd get a measurement of where they are now and how they measure compared to minimum thickness specs. In lieu of that, if you go feel the edge of your rotor (make sure they're cool) and have a large ridge or lip, you may indeed need rotors. But I wouldn't spring for them w/o actual measurements. Pads are pretty easy to do yourself, and there are several DIYs here (and lots of other places). A good set of street pads would set you back about ~150 bucks. Buy them yourself and have someone install them; or DIY and save. |
06-30-2011, 09:37 AM | #4 |
112
Rep 2,460
just change the pads, i have a z4 m and I ran the original rotors until yesterday at 58k so yeah, dont bother with the rotors unless the rotors are extremely curved on the edges to the point where they catch your nail.....
06-30-2011, 10:31 AM | #5 | |
Rep 37
for girls, it's also eazy to replace the pad? haha~ |
