TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      06-24-2011, 06:28 AM   #1
baby huey
Drives: 2013 X5M
Kidney Grille Removal - X5M
What's the secret to removing the kidney grilles? I see from the replacement units that there are a series of small plastic tabs top and bottom, but the top tabs are configured differently than the bottom ones. Advice?
      06-24-2011, 08:41 AM   #2
Spacem5
12
Drives: 2014 M5
Literally a 5min procedure. Simply use a small flat head screwdriver to loosen the clips. Start at the top clips. Once the top clips are unclipped, the grill will easily pop out. Installing the new one requires gentle pressure to snap into place. There are plenty of links, just google the topic and you will find previous discussions on this forum as well as others such as M5board.com.
      06-24-2011, 11:53 AM   #3
1MOREMOD
1MOREMOD's Avatar
11817
Drives: Race car->
what he said its super easy just start into it and they fall out almost.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      06-24-2011, 06:04 PM   #4
baby huey
Drives: 2013 X5M
Grille replacement - done
Chriszeh – you are correct, Sir. Piece of cake. SpaceM5 – your procedure may be applicable to the M5, but not for the X5M (the top tabs are not readily accessible). On the X5M, you release the three tabs on the bottom (press with thumb, not a screwdriver), and one on each side of the grille. Then pull the grille out from the bottom, and the top frees itself. When replacing with new, simply slide in evenly. Be sure to check to make sure that the bottom and side tabs all engage the new grille. A screwdriver may help with this endeavor.
      03-07-2012, 11:15 PM   #5
mdrobc13
mdrobc13's Avatar
341
Drives: Made in Bavaria
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Great info. Thanks
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten
'15 BMW M3 (Black/Black) - gone not forgotten
'10 BMW X5M (Black/Black) - gone not forgotten
'08 BMW M3 (Space Gray/Black) - gone not forgotten
      12-08-2013, 07:16 PM   #6
barcelona
barcelona's Avatar
271
Drives: X
http://www.xbimmers.com/forums/showt...ghlight=kidney
Hopefully the same.
