06-10-2011, 11:03 PM | #1 |
114
Rep 2,460
Aftermarket Flex disc/Guibo from Revshift....preliminary review...
So after that Bear Mountain Run on Memorial day weekend, I realized that after all the mods The new power on 57k old Flex Disc (aka: guibo) did not go over smoothly.....it gave out, so at low speed accelerations i get the vibrations.....badly.
I went searching....found something that replaces the oem F/D on the Drive shaft......I ordered it. I will be installing it in the morning.... It looks serious... I made a review of some sort.... |
06-11-2011, 09:34 AM | #3 |
Bad Lieutenant
233
Rep 3,517
Normally, this disc would add some NVH, but I see you're already running urethane motor mounts and trans mounts, so this will be a sweet addition.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
06-11-2011, 10:46 AM | #4 |
114
Rep 2,460
the install was perfect......NVH doesnt matter when youre running RPI and headers....I love the design that they put into this......will post pics of the whole thing shortly....
06-11-2011, 11:06 AM | #5 |
190
Rep 2,431
thanks for the info! something all of us will be looking into in the near future
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
06-11-2011, 12:07 PM | #6 |
114
Rep 2,460
ok here all the pics in chrono order.....I hope this raises guibo awareness and promotes the awesomeness that is Revshift.....lol.
F%&k Oem Bushings and Oem Rubber..... |
06-12-2011, 12:20 AM | #9 |
Rep 304
I have heard about the guibo cracking on M3s but after buying one a while back the OEM piece seems pretty serious. It makes me wonder if you hanger bearing failure may have caused the guibo to crack. While the changes you made it seems would prevent any type of failures I have to wonder what it might do to other things in the case of a failure.
06-12-2011, 02:06 AM | #10 |
114
Rep 2,460
^incorrect, by pure namesake alone one can predict that limits over the Driveshaft bearing will be pushed to the max as soon as the "flex" disc over "flexes" from more torque than it was designed for.
I mean they didnt name the driveshaft the "flex driveshaft" they named the "flex" disc a flex disc because thats what it does....it flexes...as soon as I added headers everything went weak for the guibo (flex disc) ....So that's where rev shift comes in....no flex just go.....I just finished ripping through all the gears with dsc off on the Queensborough Bridge with no problems....I intend to drive this thing into the ground only to build it stronger. I seriously suggest this mod to ANYONE dropping their exhaust to ddo any work ie; headers, clutch work, ssk, etc.... Revshift Replaces doubt with Polyurethane..... :-) |
06-12-2011, 02:15 AM | #12 |
114
Rep 2,460
Also, I will havee my old Driveshaft support bearing reverse engineered into a polyurethane composite within the same tolerancees as the UUC Motor mounts.....stay tuned...
06-12-2011, 09:51 AM | #13 | |
Bad Lieutenant
233
Rep 3,517
06-12-2011, 10:26 AM | #15 | |
114
Rep 2,460
If I can find a pair made of some rare alien metal I might get it. until then I dont see that being n issue. unless of course someone else chimes in with something of note |
06-12-2011, 10:27 AM | #16 |
114
Rep 2,460
06-12-2011, 06:40 PM | #18 |
114
Rep 2,460
unfortunately its just another oem.... a temporary fix for now as i am working on getting us a carbon fiber drave shaft which will eliminate the need for that bearing thingy
06-15-2011, 09:16 PM | #20 |
80
Rep 1,663
That sucks. It can't be the extra power from headers/etc. as I haven't seen any of our supercharged folks breaking it, maybe something else is going on.
