06-08-2011, 09:22 AM | #1 |
575
Rep 1,321
SIB Info
does anyone have a link or a source to get info on SIB 51 07 11? This is on our X6M. Looking to see if there is more info than my service advisor is giving me.
TIA, .....asked on this forum as it has more eyeballs Cheers,
Garage:
09 E90 ///M3 | SS | Black | Modded 22 992.1 GT3 | Black | PCCB | LWB | PDK 23 G82 ///M4CSL | AW | Race Buckets | 24 9YO Cayenne TGT | QGM| Burgundy | Neodyne / PCCB |
11-11-2011, 07:35 PM | #2 |
20
Rep 143
Here you go, straight from TIS. Hope this helps.
SI B51 07 11 Body Equipment March 2011 Technical Service SUBJECT Dashboard Is Deformed, Creating Creaking Noises MODEL E70 (X5) E71, E72 (X6) Vehicles produced from September 30, 2007 SITUATION The dashboard is visually deformed and can create unwanted noises when rubbing against the windshield. CAUSE One or more of the four locating brackets of the dashboard is not fitted properly into the front carrier at the bulkhead. PROCEDURE Refer to the attachment. WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle/SAV Limited Warranty as applicable.
'15 E84 X1 35i M Sport MPI DME Flash - K&N drop in - MPI Chargepipe - Oil T-stat valve - ETS 5" I/C - N54tuning 3.5" downpipe - catless mid section - Dinan 135i rear exhaust - Apex ARC8 18x9/10(255/295 tires) - H&R Sports - Bilstein B6's - F3x M Performance brakes '02 E39 530i 624whp/558ft-lbs @23psi |
