06-04-2011, 09:13 AM | #1 |
Astronaut
64
Rep 670
Zaino polishing and sealant application
My car is 3 weeks old and I plan to zaino it sometime soon. I don't have a PC, can I do this by hand? I've used the sealant before and it was just a wipe on but I plan to polish it first.
06-06-2011, 04:02 PM | #3 |
Rear Admiral
14
Rep 316
Drives: 2011 BMW M3
Zaino applied by hand is the method Zaino recommends.
--Chris
--2011 e92 M3 |
06-06-2011, 04:04 PM | #4 |
Rear Admiral
14
Rep 316
Drives: 2011 BMW M3
From the web site FAQs:
"Q: Can I use an orbital polisher to apply/remove Zaino polish? A: Yes, you can use an orbital to apply Zaino Z-2, Z-3, or Z-5. I don't recommend it because you waste too much polish that way. The pad on an eleven inch polisher can absorb almost enough polish to coat your entire vehicle. Each time you use an orbital to apply Zaino polish, you are probably wasting as much polish, if not more than you actually applied to the car. Zaino polish applies easily by hand, especially if you dampen the applicator pad with water and spritz it with Z-6 before applying it. If you use an orbital to remove the residue, you should place a white, 100% cotton towel between the pad and the paint, and keep it turned and refolded often so that you are removing the residue with a clean section of towel all the time. Note: A single orbital pad WILL NOT remove the polish residue from an entire vehicle. You will have smears if you don't use a towel and turn and refold it frequently."
--Chris
--2011 e92 M3 |
06-06-2011, 04:53 PM | #5 |
1770
Rep 6,696
Drives: F30 340i
to get rid of imperfections in the paint i dont see how hand polishing will help. orbital polisher for paint correction, hand for just a nice look.
06-06-2011, 05:00 PM | #6 |
Astronaut
64
Rep 670
Thanks all. I'm no where near ready for paint correction. I just want it to look good and protect the paint. I printed out some tips and tricks for applying Zaino from another site, i think it will help.
06-06-2011, 07:37 PM | #7 |
936
Rep 4,326
Drives: M340
You will not regret ZAINO.....!
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
06-06-2011, 08:14 PM | #8 |
70
Rep 819
Drives: 2007 M coupe
i have one for sale pm i have a flex LMK
