TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      06-01-2011, 09:59 AM   #1
mattpdx
Drives: 2018 440i
Pet Peeve - Doors don't unlock!
Is it just me or is it a pain to always have to hit the unlock all doors button after I turn off my car so my wife can get our kid out of the backseat?
Is there a solution? I want the doors to lock while driving so I can't turn that off.
I had Patryk program my car this weekend and he said he programmed the car to unlock all doors when the car is off, but it doesn't work. I have keyless entry if that helps.
What am I missing? Any help greatly appreciated.
      06-01-2011, 10:34 AM   #2
PsychoSlug
PsychoSlug's Avatar
36
Drives: E90
What do you do with any other car on the market when the doors are locked?
If you don't like having to unlock a locked door, change the setting so that they don't automatically lock when you start to drive.
      06-01-2011, 11:16 AM   #3
dmoney98
Drives: '12 3.5i Sport
Would you happened to have the "child lock switchs" engaged on the back doors?
2012 3.5i Sport X5 Verm Red (Conv, Cold, Tech, Act Steer, Adapt Drive, Muti-Con Seats, Prem Hi-Fi, Hardwire V1, BMW Personalized Coded)
      06-01-2011, 11:26 AM   #4
mattpdx
Drives: 2018 440i
The passenger doesn't unlock so that's probably not it but I'll check it
      06-01-2011, 01:22 PM   #5
kimi_fan
33
Drives: 17' X5M/91' 325i
2017 X5M  [0.00]
2014 X5 50i MSport  [0.00]
2011 X5 35i SA  [0.00]
2007 X3 3.0si  [0.00]
2007 335i  [0.00]
2003 330Ci  [0.00]
1991 325ic  [0.00]
Sounds like the "unlock when put in park" feature is another one that BMW didn't want to give us. My pet peeve, and what I want, is the side mirrors to fold in when I shut the car off and open when I start it.
Your issue sounds like something that can be fixed with coding. Since I haven't messed with mine yet I'll let someone else comment. My only hesitation on re-coding is that it may be wiped away when I take it in for service which has a reflash as a service bulletin.
17' X5M LBB
91' 325ic - Bril Red, Full Dinan Spec
(past) 14' X5 50i MSport - Min White
(past) 11' X5 35i SA - Black Saph
(past) 07' X3 3.0si MSport
      06-01-2011, 01:27 PM   #6
mattpdx
Drives: 2018 440i
I just had the coding done this weekend and now my mirrors fold in when I lock the car. It's great.
      06-01-2011, 01:59 PM   #7
scollins
Bootleggin' 'n Gunrunnin'
scollins's Avatar
137
Drives: 2024 X3 M40i
I've just developed the following habit in the X5:
Park
Parking brake
Unlock
Ignition off
Fold mirrors
But yeah, a lot of buttons to push when parking. Throw in the tailgate button on occasion too.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles
2019 Ford F450 STX, Oxford White
2013 Ducati Multistrada Touring S, Red
      06-01-2011, 05:23 PM   #8
0_steve
159
Drives: 24 X5 M60i/20 Z4
Just pull the handle twice and the door will unlock/open. No need to hit the unlock button. OR go into your iDrive and shut off the feature that locks them in the first place.
      06-01-2011, 07:41 PM   #9
pmeloche
pmeloche's Avatar
24
Drives: 2013 F25 X3 xDrive35i
If all else fails get rid of the kids.
Patrice
2013 F25 X3 xDrive35i Vermillion Red
      06-01-2011, 10:55 PM   #10
scollins
scollins's Avatar
137
That doesn't work for the kids in the rear seat with the "child lock" set. They can pull that handle all day and it won't open......
And I like the doors to lock automatically as we drive off personally, so why would I disable it? It really isn't that hard to get in the habit of hitting the unlock button on the dash....
Scott
      06-02-2011, 07:13 AM   #11
Barbja
149
Drives: 2020 X4 M40i
The 'pull the handle twice' thing should work. Its some kind of quirk on BMWs. It was that way on my '03 E53 too. I always had to explain that to new passengers in my car who thought that they had to stay there forever.
Perhaps they want you to confirm that you "really really want to get out!"?
Interesting on my '12 X6, I have to pull the handle twice on the Outside when its locked now too (comfort access). I had comfort access on my E70 and I only had to pull once.
When I first read the title of this thread, I thought it would be about a problem I occasionally had with my E53: my driver door wouldn't unlock at all when I shut off the car. Doing a 'lock cycle' with the button on the console would usually fix it, but I had to go out through the passenger door once. Nice!
      06-03-2011, 02:53 AM   #12
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
481
Drives: 06 330i 6MT
assuming patrys coded it properly and that it's a possible function to unlock when the car is off....do you have comfort access? if yes, are you completely turning the car off (press start button twice or press and hold)?
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      06-03-2011, 08:42 AM   #13
mattpdx
Drives: 2018 440i
Yes, I have comfort access. What I have been doing is putting it in park, and turning the car off by pressing twice.
Do I need to press and hold?
