TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      05-24-2011, 09:54 PM   #1
kimi_fan
33
Drives: 17' X5M/91' 325i
2017 X5M  [0.00]
2014 X5 50i MSport  [0.00]
2011 X5 35i SA  [0.00]
2007 X3 3.0si  [0.00]
2007 335i  [0.00]
2003 330Ci  [0.00]
1991 325ic  [0.00]
Lower Mesh Grill Replacement
So I got my black mesh grills just today...replacing the aluminum from the sport package with matte black to match the black performance kidney grills. Needless to say, I searched the forums and have only found a mention about replacing the lower grill in the X6 forum. The top smaller one simply snaps right in and out, the bottom, even looking at the new one, seems a little more complicated to replace.
in case anyone is looking for the part numbers you can find them here: http://www.realoem.com/bmw/partgrp.d...06&hg=51&fg=15
Numbers 2 and 3 under the Trim Decor Elements (there are 2 for each, one in black and the other in aluminum)
I wanted to confirm, or get any guidance, from someone who has replaced the lower grill on an X5 before I start taking parts off the car. I have a 35i with a January 2011 build date.
Thanks!
17' X5M LBB
91' 325ic - Bril Red, Full Dinan Spec
(past) 14' X5 50i MSport - Min White
(past) 11' X5 35i SA - Black Saph
(past) 07' X3 3.0si MSport
      05-26-2011, 03:30 PM   #2
kimi_fan
33
2017 X5M  [0.00]
2007 335i  [0.00]
2003 330Ci  [0.00]
1991 325ic  [0.00]
Anyone? I'm about to attempt this tomorrow since I have the day off before the long weekend.
17' X5M LBB
      05-26-2011, 10:36 PM   #3
c-dubmobile
Drives: 2008 X5 3.0si, 2014 335i
found a thread on another forum
http://www.xoutpost.com/bmw-sav-foru...all-black.html
      05-27-2011, 07:45 PM   #4
pmeloche
pmeloche's Avatar
24
Drives: 2013 F25 X3 xDrive35i
It's grille not grill.
Patrice
2013 F25 X3 xDrive35i Vermillion Red
      05-28-2011, 12:13 AM   #5
kimi_fan
33
2017 X5M  [0.00]
2007 335i  [0.00]
2003 330Ci  [0.00]
1991 325ic  [0.00]
Ha ha, must be a Canadian spelling.
Replaced them today, wasn't that bad. I'll post some pics and comments when I get a chance.
17' X5M LBB
      05-28-2011, 03:16 AM   #6
ZuerstBMW
¡Viva España!
ZuerstBMW's Avatar
373
Drives: 2023 230i Mineral White
Actually, In the United States, "grille" is used to differentiate the automotive part from the cooking device, called a "grill".
Yes, please post pics.
23 G42 230i Mineral White Cognac, Aluminum With Mesh Effect Interior Trim MODS Clear Guard, 15% Ceramic Tint, Floating Caps
      05-29-2011, 11:49 AM   #7
kimi_fan
33
2017 X5M  [0.00]
2007 335i  [0.00]
2003 330Ci  [0.00]
1991 325ic  [0.00]
The following describes what you'll need to do to replace the front grills (or grilles) on an E70 35i. For me this was all about replacing the grilles from the aluminum finish to the matte black finish to match the blacked out BMW performance kidney grille. Thanks to the Jason at Tischer for sending me the correct part numbers...and the quick shipping once the part came in...my only advice is to make sure you're getting the right part as cars with Active cruise may use a different part. Replacement actually isn't as difficult as I thought it may be and only took a total of 1.5 hours...you could probably do this faster but I was being careful not to break anything. First, the small top grille simply snaps on and off and could be swapped out in about a minute. The bottom one however requires that you remove the front bumper cover because of the way it snaps in and the fact that you have some support bars in your way that do not allow you to swap these out without removal of the bumper.
Tools you'll need: 8mm socket, flat head screwdriver for prying if necessary, and a phillips screw driver. It is also helpful to have a friend or someone to help hold one side of the bumper as you remove the other side. A box or other support would also work.
Here you go:
1. Remove the 4 screws (phillips, quarter turn screws) under the front aluminum colored skid plate.
2. Remove the 2 screws on the left and 2 on the right under the car that hold the bottom of the bumper to the trim (8mm small screws).
3. Remove the 5 screws along the top of the bumper, just above the small grille in the front of the car (8mm screws with the large heads).
4. Remove the 3 screws on the left and 3 on the right in the wheel well that secure the bumper to the fender flares in the front.
5. At this point you should have removed a total on 19 screws (4 aluminum colored phillips, 5 8mm screws with the big head, 6 8mm screws from the wheel wells, and 4 small 8mm screws from under the bumper.
6. The next part for removal is all about patience as it requires unsnapping a few things. The front fender flares are snapped into the front bumper using tabs...this was actually the hardest one for me to remove. Unsnap the flares from the bumper on both sides.
7. The bumper is free now, other that the tabs at the tops of the bumper on the left and right that are holding it in. My technique was to rock the bumper off, holding the top and bottom of the bumper, on one side. Once one side is free (I started with the driver's side) you'll need to disconnect the wiring harness that powers the fog light. This is where your friend, or a box, needs to hold one side up while you work on the other. I removed the passenger's side using the same technique...keep in mind you'll have both the fog light and PDC wiring connection on that side that needs to be disconnected.
Your bumper should now be free and you can unsnap the old grille and replace with your new one. As a side note, if you plan on replacing the grilles on the left and right (the one's with the aluminum horizontal fins) with the open one's like the 50i has now would be a good time since they appear to be easily removed only after you have the bumper off. I'm not sure if that's a good idea just yet, since in the 35i there is nothing behind them and it looks like there is a limited amount of space for air to escape...which i can only imagine would assist in lower my gas mileage.
Replacement is just the opposite of removal. My only tips are to take your time, make sure everything is back together correctly (the fender flares have a piece that gets tucked in, which is nearly impossible to do while snapping the bumper in from the front by yourself...have a friend help with this as well), and make sure you reconnect PDC and the fog lights before you put it back. I also checked the lights and PDC before screwing everything back together just to make sure I reconnected everything.
Hope that helps!
17' X5M LBB
      06-07-2011, 11:49 PM   #8
alextclam
Drives: 2023 X5 40i
Hi,
I just ordered the black performance kidney grilles from my dealer today and was wondering how easy or hard was it to swap out? Thanks.
      06-08-2011, 09:13 AM   #9
kimi_fan
33
2017 X5M  [0.00]
2007 335i  [0.00]
2003 330Ci  [0.00]
1991 325ic  [0.00]
The kidney grilles snap in and out very easily. There are only tabs holding them in. Pop the hood and you'll see what I'm taking about.
17' X5M LBB
      06-08-2011, 10:57 AM   #10
alextclam
Drives: 2023 X5 40i
Ok thanks, waiting for them to arrive.
      06-24-2011, 10:36 PM   #11
c-dubmobile
Here you go:
Hope that helps!
Super detailed instructions! I'm gonna try to replace my black ones w/ the silver ones soon!
      06-25-2011, 01:14 PM   #12
sammybmwfan
Drives: Bmw x5 4.8i
Hi there, I was wondering: should i replace the mesh as well? I think i have hit some brush or whatever. Since then i have this irritating noise, which I am not quite able to locate, but it sounds plasticlike.. Thanks for your help.
      06-26-2011, 11:27 PM   #13
kimi_fan
33
2017 X5M  [0.00]
2007 335i  [0.00]
2003 330Ci  [0.00]
1991 325ic  [0.00]
Up to you. I replaced mine for cosmetic reasons, but if you think something is loose you could always pull off the front bumper and check.
17' X5M LBB
      03-17-2012, 01:29 AM   #14
mreuterusa
Drives: X5
Could you post this in the DIY section? I was looking and searching for hours to find how to remove the bumper on the E70!
Thank you!
      03-17-2012, 12:29 PM   #15
kimi_fan
33
2017 X5M  [0.00]
2007 335i  [0.00]
2003 330Ci  [0.00]
1991 325ic  [0.00]
There's a DIY section? Where? If there is I posted this last year some time when I swapped the grilles.
17' X5M LBB
      04-10-2012, 05:45 PM   #16
M3LLO
M3LLO's Avatar
22
Drives: 2012 F10 550I xDrive
Nice write up! Just did this today on my '11 E70 X5 50i. Installed the gloss black kidney grilles and swapped the silver mesh for the black mesh. Took me about an hour total and it looks great!
      09-05-2012, 04:12 PM   #17
tommyboyLondon
Drives: 2010 X6 xDrive30d
Just fitted mine
And I did it without removing the bumper.
The only thing I did was unscrewing the screws at the bottom so that
I could pull the bumper slightly away and push the grille inside.
Once you unsnap all the hooks slightly bend it and pull it out through the grille hole.
Do the reverse with the new one, snap it in and screw the bumper back on.
      01-14-2014, 09:30 PM   #18
petelebel
Drives: 08 328i wagon
Hello. I have a similar x5. My problem however is that the bumper cover is separating from the fender on the right side. I looks like there is a lever joining the fender flare to the bumper cover. You refer to the "unsnapping" of the fender flare from the bumper on your item #6. How do you do this exactly? Please feel free to post any other picture you may have. What you have posted to date is very helpful. As there does not seem to be any instructions for the E70 LCI, I am trying to gather as much information as possible before I try to repair this small gap. I pulled the fender liner and I saw the tabs you mentioned, but the connection of the pieces right at the edge of the wheel well has me scratching my head. Thanks for your help.
Pete
      01-15-2014, 09:46 AM   #19
kimi_fan
33
2017 X5M  [0.00]
2007 335i  [0.00]
2003 330Ci  [0.00]
1991 325ic  [0.00]
I don't have any other pictures that I didn't post, and apologies as I did this quite a while ago so my memory is a bit fuzzy. One thing I do remember is that the flares are snapped in to the bumper (you can see the tabs in the pics I posted of the flare), and you'll need to remove the bottom 2 screws for each flare on each side of the car. There are also other rivet-like fasteners above the 2 screws that hold the flares to the bunper and then the quarter panel. I was able to unsnap the flare without having to remove the rivets, however if you remove the rivets I believe you'll need to replace those as they are not re-usable.
Sorry, I know that's much help.
17' X5M LBB
      01-15-2014, 08:43 PM   #20
petelebel
Thanks for the response. I see there is a track which grabs the edge of the bumper cover. I suspect my bumper cover just freed itself from the track. I'll pick up some rivets at the dealer in the next few days and get to work removing at least 1/2 of the bumper cover in order to reinstall. Thanks again. Your pictures have been most helpful.
Pete
      05-09-2014, 04:12 PM   #21
x5joe2013
x5joe2013's Avatar
Drives: 2013 X5 50i
Thanks for the tip on being able to do this without removing the bumper. I did it today in about 30 min.
It does take some patience and quite a bit of hand strength, but it worked it way out.
