05-14-2011, 07:30 PM | #1 |
204
Rep 835
How to remove/prevent bird drop marks
As the title says. My car sometimes sits outside all day and when I return home there might be a small bird dropping. Is there any products that remove it safely and also any left over etching??
My car is white and I can't really notice any marks but I want to now what I can use. Many thanks
F82 M4 AW
Ferrari 599 GTB Fiorano Jeep Wrangler Unlimited Previous BMW: E36 Reiger Custom Green vert E46 ///M3 Cabonblack vert E46 ///M3 AW vert E63 645ci AW Coupe E92 ///M3 AW E93 ///M3 SG Vert |
05-16-2011, 06:18 AM | #3 | |
93
Rep 2,528
Oh, so this was a question? From the title I was looking forward to learning something.
"But resist we much; we must; and we will much; about that be committed." ~Rev. Al Sharpton 2010 E92 M3|Silverstone II|M-DCT|NCSW|2MT|ZCW|ZPP|ZTP|302|507|Gas Guzzler Tax |
05-16-2011, 07:23 AM | #4 | |
43
Rep 2,406
05-16-2011, 02:01 PM | #5 |
204
Rep 835
Yes this is a question, and when it's answered the title serves as a purpose for those in need as well.
I have a car cover from BMW, but I heard it does more damage to the paint then leaving it off. Any inputs would be great as I'm sure many keep their M's outdoor and could use some advice. Thanks
F82 M4 AW
05-16-2011, 04:01 PM | #6 |
27
Rep 872
CarbonAlpine,
It is a good question and the thread has proven that others have the same question. Luckily with your car, the vehicle is white and therefore doesn't absorb nearly as much heat as a darker colored car would. Never the less, acid damage doesn't discriminate and can negatively affect all vehicle finished. Keep a bottle of quick detailer in your car along with a couple quality microfiber towels (put them in a zip-lock so they don't get any other debris on them while they're waiting to be used). It's worth pulling the car in the shade and giving affected areas a few minutes (5-10) to cool off so that any quick detail sprayed doesn't evaporate away as soon as it hits the finish. Spray with the intention of soaking the crap so that it loosens from the paint and can be gently wiped away. After a couple of sprays, gently wipe, turn the towel, and wipe again. There's no product to apply to simply remove etching damage. The nature of etching damage is a permanent damage to the affected paint. Hopefully you can prevent the damage from going too deep however, so that with polishing the damage can be safely removed from your finish. |
05-16-2011, 11:40 PM | #7 |
204
Rep 835
^^thanks pal. Would droppings left on car for about 6 hours do any damage? That's around the time that I'm away from my car. Is using a car cover safer??
I use DP waterless wash... Thanks again!
F82 M4 AW
05-17-2011, 12:41 AM | #8 | |
27
Rep 212
2011 e92 M3: AW/blk zcp, dct
2008 Civic Si FG2 ASM/blk 2005 e46 M3: SG/blk zcp, 6MT (sold) |
05-17-2011, 09:04 AM | #9 | |
27
Rep 872
I can't tell you how long it'll take. Maybe just an hour. Maybe 6. Maybe 12. There's no set amount of time as there are so many factors. Car covers can cause a lot of marring to your finish as well as swirls. I personally avoid them like the plague. They certainly can protect the paint, but they can also be damaged by bird droppings and other etching based damage. They might not work 100% in all cases, but I'd imagine they would help greatly at the cost of being expensive and not looking as nice because of orange peel and dis-colorization over time. Of course not all paint protection film is equal and a lot will depend on your installer. |
05-17-2011, 12:55 PM | #10 |
Putcha ang ganda...
281
Rep 5,441
i better post my hood a fawking crow shit on it. or maybe a seagal its one big shit and now i need to have the hood detail...
05-18-2011, 02:38 PM | #12 |
drop a gear and...
79
Rep 967
I had some really bad bird poo on my Jet Black hood. I didn't have any detailer with me so it took about 3 hours to get it washed off. The etching is so bad that it's still visible in direct light after 6 sessions with a PC DA polisher and an orange pad. I took it to a pro and he suggested wet sanding to completely remove the spots so it will have to stay for now.
A few of the drops landed on my clear bra that covers only the front of my hood and after the pro couldn't remove them without damaging the bra I had to replace the clear bra. The bra actually looked worse than the hood - With the hood you have to be at just the right angle to see the spots, on my bra it was obvious where they were at any angle.
05-18-2011, 04:40 PM | #13 | |
13
Rep 254
05-18-2011, 04:47 PM | #14 |
drop a gear and...
79
Rep 967
About 3 hours.. But it was also on the hot hood in the sun.
05-18-2011, 08:06 PM | #16 |
204
Rep 835
Is there anything that deters birds besides paintballs? Or will they continue to come back??
F82 M4 AW
05-18-2011, 09:54 PM | #17 | |
Troll
79
Rep 1,193
reminds me of an old thread on 1addicts... What would you do if this was you:
BMW E92 M3 Coupe | Jerez Black | Fox Red Extended / Carbon Black Trim| Fully Loaded | Moonroof | 6MT | Gintani Sport Quote:
05-19-2011, 06:55 AM | #19 |
drop a gear and...
79
Rep 967
Take it for a repaint and buy a shotgun on the way home... j/k
05-26-2011, 02:59 PM | #20 |
38
Rep 543
I came out to my Jet Black M after a meeting. The car was in the Houston sun for approximately 3 hours. In that time a bird nailed the trunk. I brought it to an excellent detailer, and after buffing and polishing it is still noticeable. At this point it appears wet sanding is the next option. When I did this search I was hoping for a miracle cure. Oh well..........
05-26-2011, 03:34 PM | #21 |
Rep 49
One thing to note is that if bird crap is a problem for you, carnauba waxes will protect it better than sealants. I'm a sealant guy but we don't too big of a bird crap problem in our area, doesn't seem to be as acidic as it does in other areas.
The reason being that polymer sealants molecularly interlock with the paint, meaning that the bird crap will transfer through the sealant and into your paint faster. Waxes more sit on the paint rather than really bind to it, creating a barrier which the bird crap will have to eat through before making it to the paint. Hope this helps |
