03-23-2011, 01:49 PM | #1 |
29
Rep 164
Trunk lid/rear of car - lots of spots (w/ PIC)
The rear of my car has a number of small black, grey and caramel-colored spots that do not come off during a normal wash. However, after using a bug/tar remover on a small test area, the spots came off pretty easily. But I'm hesitant to use a cleaner that's potentially too abrasive over a wider surface area. Any thoughts/advice??
I have the Akrapovic Evolution exhaust w/ 100 sports cats, but I'm not sure to what extent it's contributing to the discoloration. The photo was taken after a wash. |
03-23-2011, 01:51 PM | #2 |
The Jesal
391
Rep 5,859
Use a clay bar.
2009 E90 M3 - SOLD
03-23-2011, 04:58 PM | #3 |
Putcha ang ganda...
281
Rep 5,441
wash the car
wipe it dry get the quick detailer spray while its wet clay it... and wipe... then wax the car and for final use carnauba wax to protect the seal
03-23-2011, 08:54 PM | #5 |
Rep 25
Got that too. Comes off with rubbing but would love to know what it is. It's ON the paint. Looks lik tiny rust spots
E92 2008 M3 Coupe
Eibach Pro-Kit Springs Active Autowerke short-shifter Carbon-Fibre everything |
03-23-2011, 10:15 PM | #7 |
169
Rep 659
Drives: 2007 E90 335i / 2011 E90 M3
Common issue for vehicles driven in snowy climates. The surface rust (which can appear even on plastic panels such as bumpers) is the oxidation of residual metallic compounds found in road salt and other snow melting agents deposited on roadways.
Nothing a little elbow grease, read clay bar or wax won't fix. A |
03-24-2011, 04:41 PM | #9 |
322
Rep 17,316
Drives: E92 M3, E30 325i
medium grade claybar should do the trick as others suggested.
03-24-2011, 04:43 PM | #10 |
definitivecars.com
354
Rep 3,833
Drives: Elsa - 2015 F80 M3 - YMB/SS
Garage List 2011 E90 M3 [6.66]
2009 (Lease up Sept ... [0.00] 2007 (Lease up 6/19 ... [0.00] 2007 (Lease up Octo ... [0.00] |
I have these as well, and even after a full detail with clay, they are still there. Mine even look like they are under the paint... I have stock exhaust with cutouts. So I dont think its the exhaust...
But I would also like to know how to get rid of them. D |
03-24-2011, 07:40 PM | #11 |
40
Rep 318
Like I was saying, with IronX (previously iron cut), it just dissolves the rusts spots then use a microfiber to agitate, then rinse and wash. It will remove small rusts spots that you're not even seeing. it will remove them much more in depth than a clay bar ever will.
03-25-2011, 09:22 AM | #12 |
268
Rep 1,883
Drives: 2011 E92 M3
Had the same thing, clay bar took them right off with minimal effort.
'11 BMW E92 ///M3 - ZCP and DCT
'15 Ford F-250 - Lariat, 6.7 Powerstroke Turbo-diesel |
