03-20-2011, 10:58 AM | #1 |
Rep 44
95 vs 98
Hi, like to ask if any of you folks have experiences any differences in terms of (1) performance and (2) fuel efficiency from using 95 octane vs 98 octane gas?
Thanks. |
03-20-2011, 01:24 PM | #2 |
Rep 630
Never did when I had gasoline engine cars.
"Let our manners distinguish us from our enemies, as much as the cause we are engaged in"
03-20-2011, 02:03 PM | #3 |
Mario
26
Rep 981
Yes and Yes, on my Mini Cooper. Not by much but I can notice the difference.
"Do or do not, there is no try!" - Master Yoda
"Always in motion is the future" - Master Yoda "Truly wonderful, the mind of a child is" - Master Yoda "There is no passion to be found playing small - in settling for a life that is less than the one you are capable of living" - Nelson Mandela |
03-20-2011, 02:05 PM | #4 |
14
Rep 82
The measures of performances by BMW are done with octane 98
Racing is in my blood. A. Senna
03-21-2011, 03:07 AM | #6 | |
Rep 630
On the long term though, engines may react differently in terms of wear and tear depending on the octane indice. But how to figure it out for the average driver is quite a challenge !
03-21-2011, 03:47 AM | #7 |
Mario
26
Rep 981
German cars in general are optimised to run on 98 RON. High performance (high compression) engines, and BMW petrols fall under this category, will give around 2-5% greater BHP (KW) output over the 95 RON fuel. Whether you will notice it is a matter of opinion but I think a very experienced driver would, particularly if he/she knows the car really well. Its definitely measurable though.
In addition the higher the octane the cleaner it burns so emissions are less, injectors are cleaner and milage is better. Again the difference is small so it really comes down to price. 98 is marginally better than 95 but is it worth it? Your choice. I always use 98 (or higher) if its available.
03-21-2011, 04:21 AM | #8 | |
Rep 630
03-21-2011, 05:34 AM | #9 |
Mario
26
Rep 981
Actually, don't even think of putting Avgas (petrol equivalent) into your petrol car. It contains lead which will destroy your catalytic converter. Just for interest it comes in two octane levels, 80 for very old piston engines and 100 for the newer ones. Some car "super" petrols have the same RON rating. The same is true for diesel engines. Avtur (or Jet A-1) will run in a diesel car but again will wreck it as it does not have the same lubrication qualities. You can add additives etc etc but why?
03-21-2011, 05:37 AM | #10 | |
Rep 630
So let me get this straight: If you feed AvGas 80 in your Mini will she sound just like a Sptfire's RR Merlin mill ?
03-21-2011, 05:53 AM | #11 | |
Mario
26
Rep 981
Heh, heh, I used to work in the aviation industry
03-22-2011, 07:44 AM | #12 |
144
Rep 491
Yes, modern cars can change the ignition timings a little to optimize the combustion, so they can accommodate a wide range of petrol standards/quality. This is all controlled by the car's ECU. The only harm is done when the timing is advanced by force (workshop tuning) and low octane petrol is used. Slight knocking might occur and in the worst case, detonation!
Anyway, we are not talking about large gains in power with using different octane petrol. It is more on the behavior/response of the car. You might find that the engine runs a little smoother, slightly more eager to rev, less vibrations during idle, a little more responsive to the pedal etc. We are talking about very little. Like Mario mentioned, you really have to be "in tune" with your car to feel the differences. There might be slight gas mileage differences as well. But of course, still largely dependent on your driving habits. |
