03-14-2011, 02:39 PM | #1 |
41
Rep 976
Detail Addict - 2009 Chevy Camaro
This is actually a pretty old write-up... But since I haven't posted it here before... here you go!
------------------------------------------------ 2009 Chevy Camaro This car is only about 1.5 months old. The dealership did a very hacked job on it and filled EVERYTHING. It looked nice, but once we stripped everything, it was halogram EVERYWHERE. Although it's new, it has some very sever RDS and minor swirl marks. The entire process took about 20 hours or so... Wash - Camspray Foam Gun - Detail Addict Water Softening System - Detail Addict Car Soap - Detail Addict Grit Guard - Detail Addict Wash Mitt - Detail Addict Waffle Weave Drying MF - Detail Addict Engine+Wheel Cleaner - ACE TurboStick Clay/Polish/Wax - Porter Cable 7424XP - Makita 9227C - Detail Addict Backing Plate - Detail Addict CCS Pad Set - Detail Addict Medium Grade Clay Bar - Detail Addict Detail Spray (lube) - Menzerna Power Gloss (S34A) - Menzerna Super Intensive Polish (83) - Menzerna Super Finish Polish (106FA) - Menzerna Final Polish (85RD) - Detail Addict Sealant Wax Miscellaneous - Detail Addict Glass Cleaner - Detail Addict Glass Towel - Detail Addict Rub&Shine - Detail Addict Dressing Sponge - Detail Addict Polishing MF - Detail Addict Detailing/Polishing MF Sorry, it was very cloudy so no good pictures of before outside... We start with the wheels and tires Off with a hand brush to get the spokes Then with ACE PowerStick to get to the inside of the wheels Pressure wash off everything Including the wheel wells Then we start with the body to get the 'big dirt' off the car... Hit the tires again as we rinse the body Then off to our Camspray Foamer You can never clean the wheels/tires enough! Then off to two buckets hand wash with fresh MF Then glide the water off of the car Rinse down the wheels of course Look at this! Brand new car! This is from just the hood too! Air dry all the gaps and surfaces as much as we can After air dry, we use Waffle MF to blot dry Look closely, lot of RDS! We then took a paint meter to check the thickness and it was about ~145-185 micron all around. Plenty of paints on this car for correction! and swirl marks Recommended Products Still trying to perfect close up shots... But yeah, lot of swirls... Here are bunch of 50/50 Some indoor finishing shots The sun finally came out the next day for us to take some outside pictures! |
03-14-2011, 03:08 PM | #2 |
69
Rep 2,382
A freshly detailed black car is the best looking. Nice work indeed.
2016 F80 ///M3 [YMB / Black Full Merino / Carbon Fiber Trim / DCT / Everything] I picked DCT because I want to be more involved in my un-involvement.
