02-28-2011, 04:51 PM | #1 |
432
Rep 4,567
Factory spacers on the GTS
Sorry if this isn't news to most, but...
Thanks to a little bit of research from Ralf (Checkcaptain), Ian (alpina527), and Byron (beedub) it's been determined that that GTS wears 5mm spacers on the front wheels (no spacers on the rears) in order to clear the front springs. Based on previous posts by Tom @ EAS and rldzhao, I've been under the impression that the minimum spacer size that will fit our hubs is 12mm. Any idea how BMW was able to fit a spacer so small on this car? The GTS also has a stud conversion from the factory -- is this the answer? Would love a bit of clarity from our resident suspension experts.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem Last edited by aajami; 02-28-2011 at 05:48 PM.. |
02-28-2011, 06:49 PM | #2 |
808E90
233
Rep 4,047
I've ran 5mm spacer on my stock hub ... No problems.
LTMW FTL . Karbonwerks LCI Trunk . Vorsteiner Poly Front Lip . NA Motorsports LUX H8 . RECARO Pole Position Seats . BMW Performance Pedals . BMW Performance Performance Grills . BMW Painted Fender Grills . BBS 19x9.5 19x11 LMs . Michelin PS2 265/295 . H&R Sport Springs . Wheel Mate 45/55MM Stud Kit . BBS Red Lug Nuts . ESS VT1 Supercharger . Akrapovic GT4 Exhaust
02-28-2011, 06:51 PM | #3 |
432
Rep 4,567
Here's the thread that from LMBM3 (I miss him) where he explains where anything less than 10-12mm spacer is not recommended for our cars:
http://www.m3post.com/forums/showthread.php?t=307901
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
02-28-2011, 07:04 PM | #4 |
808E90
233
Rep 4,047
Those spacer that are pictured next to the hub centric spacer look like universal ones ...
The problem with running universal spacers is that they do not sit tight around the hub. The reason you want to go with a 10-12mm spacer is because it will extend the hub (where the wheels sits on). For those that want to run a 5-8mm spacer and are concerned about the amount of area (hub) that the wheel will sit on you can always get these: http://www.turnermotorsport.com/p-21...ders-pair.aspx
02-28-2011, 07:42 PM | #5 | ||
BimmerPost Supporting Vendor
8236
Rep 18,833
Drives: BMW
Spacers 10mm or larger should be hubcentric. Most 3mm & 5mm spacers do not need to be hubcentric since the stock lip (11mm) has enough to protrude the wheel centerbore. Most 10mm, 15mm 18mm and 20mm are hubcentric, allowing the wheel to properly center itself to the hub and prevent vibration. Stud conversions simply allow easy wheel removal at the track as well as eliminating the need for specific lengths for different spacer thicknesses.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
03-01-2011, 03:02 AM | #6 | |
60
Rep 638
BMW wheels have a 6mm x 30 degree lead chamfer which means anything over a 3.8mm spacer has no location on the wheel spigot. |
03-01-2011, 01:40 PM | #7 |
445
Rep 1,658
5mm spacers are fine in most cases as they can keep the car 100% hub-centric. It seems there is a LOT of misinformation about what hub centric really means, and how spacers effect a hub centric fitment.
Just because 5mm spacers do not have an extended hub, does not make the wheel assembly non-hub centric. As long as hub material is making contact with the center bore, the assembly will remain hub centric, and in most cases a 5mm spacer works as there is enough of the factory hub sticking through, that everything remains centered. Hub centric means the hub keeps the wheels centered. The lugs hold the wheels to the car. This is important to understand, because the hub itself holds very little load on it's own. It's simply a guide to keep the assembly centered as there is a lot of slop and play with BMW lugs. Many cars on the other hand are lug centric. Meaning the hub is meaningless and the lugs don't have the same slop. They can center the wheels on their own. Two different designs, both work. BMW chose one. The important thing to remember about the above is that the hub on a BMW only has to keep things centered, which is not a complex task. To do that, it only needs a few millimeters of contact with the wheel. Most BMW hubs have about 10mm of hub extension. If that sticks into a wheel 10mm, then you can use a flat spacer so long as there is still a few millimeters of material making contact with the wheels center bore. Some wheels have a chamfered edge on their center bore, while others don't, and that chamfer can very in depth as well. That has an impact on how deep the hub has to reach to make proper contact with the center bore. In most cases a 5mm spacer will still have a few millimeters of center bore contact even on a wheel with a chamfered center bore. An 8mm spacer on the other hand would not leave enough hub to keep the wheel centered since most wheels have a chamfered edge that is a few millimeters deep, that would make it impossible for the remaining factory hub material to make contact with the wheel. Because an 8mm spacer is flat (no attached hub extention) people tend to pool them all together and make generalizations. The spacers shown in that thread above are NOT a universal spacer. They are still a bmw specific spacer as they are 5x120. It doesn't need an extended hub, as the factory hub does that work, and it would be impossible to create 5mm spacer with an attached hub. In Summary: The chamfer of your wheels are the determining factor of whether or not a 5mm spacer will work.
Last edited by Eddy@ApexWheels; 03-01-2011 at 02:19 PM.. Reason: fixed one of the many spelling errors that are most likely still there ;) |
03-01-2011, 02:08 PM | #9 |
423
Rep 5,329
great post paintpro......
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
03-01-2011, 02:41 PM | #10 |
60
Rep 638
Yes great write up, but the 359m wheel in question has a 6mm deep chamfer.
The stock GTS spigot has 9.8mm of effective location. Add a 5mm spacer and the wheel isn't locating properly. In fact it's 1.2mm short of getting any location at all. That is why we are trying to work out how the 5mm GTS spacer is working |
03-02-2011, 12:19 PM | #11 | |
445
Rep 1,658
03-02-2011, 02:17 PM | #12 | |
60
Rep 638
It would be great to get some actual photo's of the GTS spacer setup to see what's going on in there. Can you help? |
04-03-2011, 12:33 PM | #14 |
432
Rep 4,567
So is it safe to assume that BMW eschewed bolts on the GTS in favor of a lug-centric setup in order to allow the use of a spacer with a 359M?
04-04-2011, 07:57 AM | #15 | |
2297
Rep 13,005
If the factory is using 5mm spacers with the 359M then the logical conclusion should be either the GTS hub is not 9.8mm or this GTS 359M center bore does not have a .8mm chamfer. I think that the factory knows a little bit more than any of us combined. |
04-07-2011, 05:21 AM | #17 |
60
Rep 638
04-07-2011, 02:14 PM | #20 |
892
Rep 9,032
Apparently, the wheels are a motorsport wheel they already had available and they didn't want to make a new wheel for a few hundred cars.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
04-07-2011, 02:37 PM | #21 |
130
Rep 1,512
04-07-2011, 05:24 PM | #22 |
432
Rep 4,567
Apparently the 1M Moto GP pace car is also wearing 5mm spacers on the fronts as well.
