01-09-2011, 01:57 PM | #1 |
Rep 96
SWS 8 / Amp install (spacers, wire harness)
Just wanted to give props to Technic and jtsherri on the products I purchased from them. Technic makes the wire harness which connects to the OEM wire harness and jtsherri makes the subwoofer spacers. Both products are superb in quality and makes the install pain free and reduces the time you would have to cut an spice into the OEM wires and fabricate the spacers on your own. Thanks Elias and Jason. If you are going to do this upgrade I highly suggest you contact these two forum members fo their products, you'll be thankful you did.
01-09-2011, 06:29 PM | #3 |
121
Rep 1,246
Drives: 2015 LBB F85 X5M
can you post some pics from your installation?
01-09-2011, 06:53 PM | #4 |
Rep 96
Sorry I did not bother since there are numerous threads with pictures and advise already.
http://www.m3post.com/forums/showthr...&highlight=sws http://www.e90post.com/forums/showthread.php?t=163804
01-10-2011, 09:04 PM | #5 |
13
Rep 156
I will definitely use their products. A few quick questions:
1. Did you have the standard sound system to begin with? 2. Was the transition pretty amazing? 3. How much did the total conversion cost? I need to budget with my wife. ;-) 4. If you replaced the stock subs are you getting the right balance of bass?
Hoeferland | 2008 E90 M3 | Alpine White | 6MT | 20" HRE P40s | Full Active Autowerke Cat-less Signature System | BPMSport Stage 2 Dev Tune | Eibach Springs & E36 Bumps | EvoSport Underdrive Pulley
01-10-2011, 09:24 PM | #6 |
Rep 96
I have the premium sound system, I had an amp lying around so it reduced my costs. I would estimate I spent $450. I think it is a good bang for the buck upgrade. You won't get the full spectrum of bass but it's leaps better compared to the stock subs. I still have not fine tuned the crossover and equalizer settings so once I do it will sound better than it already does.
01-11-2011, 02:36 PM | #8 |
17
Rep 286
Drives: 2009 LeMans Blue Coupe
Much props to Technic and jtsherri but you know this is posted in the For Sale section? Speaking of which I need to check my battery still and get back to you Technic (I know its been a couple of months now).
01-11-2011, 05:53 PM | #9 |
Rep 96
Yeah there is a Vendor Comments/Review/Feedback Forum, however they are not vendors. This is the only section that fit the closest. The thread has been here for a few days now. If there was an issue the Mods would have erased or moved it.
