01-06-2011, 06:37 PM | #1 |
19
Rep 389
Dead battery
dealer says battery is dead, they say the car has too few miles (25K) and that the warranty does not apply because of this. Anyone else had this problem? They want $450 for a new battery...
'12 Nero/Rosso 500 Abarth
'07 IR/SBL ///M Roadster (GONE), '08 Tornado Red Triumph Daytona (GONE), '09 BRG/Cloth 6MT MINI Cooper S (Spontaneously Combusted), '06 IR/IR ///M3 Convertible 6MT (GONE), '04 JB/CR Z4 2.5i SMG (GONE) |
01-06-2011, 06:52 PM | #3 |
M = Midlife Crisis
65
Rep 2,006
It's 4 years old - why would it be defective? I don't believe batteries are covered by warranty beyond year 1 unless a component failure lead to the battery failure.
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM |
01-06-2011, 06:52 PM | #4 | |
Dog Listener
704
Rep 7,850
Are you sure the battery is really "gone"? What if the car is jump started and you drive it 50 or so miles to charge it? I ask because I don't trust folks who sell batteries to provide an honest evaluation.... The wife's 07 Z4M had a dead battery a few weeks back. The tow truck jump started the car and the battery has been fine ever since even though the driver (who sells batteries) said it needed to be replaced. I just hooked it up to my Christmas gift (CTEK Multi 7002) that among other things tests the battery to determine if it's in need of replacement. No surprise here but it did say the battery was fine. However, it was running a very low level of charge even after a 50 mile trip which was indicative of a deeply discharged battery. The 7002 has a "Recondition" feature that basically fixes deeply discharged batteries. After running through that cycle it now holds a full charge. Knock on wood it won't need to be replaced for several more years. The charger also can deal with sulfurization and correct that and other bad conditions as long as the battery isn't too far gone. If you don't drive the car frequently something like the CTEK 7002 is highly recommended and cheap relative to a new battery and more importantly the hassle that comes with a dead one at the most inopportune moment. |
01-06-2011, 07:32 PM | #5 | |
502
Rep 1,543
What's difference between the two models? I still have some time to return and upgrade to 7002 if it's necessary. TIA, |
01-06-2011, 08:04 PM | #6 | |
Dog Listener
704
Rep 7,850
Either model is super-easy to use and a good way to increase the useful life of a battery--especially if you don't drive long distances or drive the car daily.... |
01-06-2011, 08:47 PM | #7 |
379
Rep 1,002
Drives: 2007 Z4 M Coupe 2012 e93 M3
Is your car still under warranty? Mine was replaced for free around 19k miles! I later found out the TCU and center console door were not functioned properly (hence drained the battery). Both were fixed as well. Try to make a habit of locking the car so it will completely shutdown everything (if not, some modules will stay ON for 15 minutes). A battery tender is great idea if the car does not get driven often (or short trips only)
01-06-2011, 09:17 PM | #8 |
Skull Squadron Leader
307
Rep 2,031
Battery tenders FTW. I have mine on tender if I don't drive it for a while. Thinking about changing battery at year 5-6 though, just as preventative maintenance...
01-06-2011, 09:58 PM | #9 |
Car Guy
31
Rep 796
I was traveling a lot last year and didn't have time to attempt a warranty claim when mine died. I replaced mine with an AGM battery with the exact same specs from Oreilly Auto Parts (P/N 48AGM @ $154.99).....it even looks the same as the OE battery other than the stickers:
http://www.oreillyauto.com/site/c/de...3321&ppt=C0005
01-06-2011, 11:30 PM | #10 |
your average JAMF
3101
Rep 4,094
Drives: '21 M2 Comp, '19 Golf R
$450???!!!! I sincerely hope they include a reach-around at that price. What's list price for the battery, isn't it ~ $200? Wow.
'21 M2 Comp
'19 Golf R |
01-06-2011, 11:38 PM | #11 |
265
Rep 527
I had a dead battery earlier this year. I am the second owner of a low mileage 2006 car (had 14k on the clock when I bought it). BMW WILL NOT cover the battery if it is not operated at a certain mileage level each year to ensure that the battery is consistently receiving a charge. Not only that, but they also don't cover batteries at all unless the battery failure is caused by a fault in the charging system of the car and they charge a hefty amount just to check that out. I ended up going to AutoZone, spending $130 on an AutoZone gold top battery, and put it in myself in about 15 minutes - problem solved.
01-06-2011, 11:42 PM | #12 | |
1136
Rep 2,867
Drives: Anything
01-07-2011, 12:09 AM | #13 |
140
Rep 1,991
According to the web site the O-Reilly battery is as follows:
# Cold Cranking Amps: 760 # Cranking Amps: 875 # Reserve Capacity: 120 No listing for AH. It seems to be identical. That is where I will be going when I need a new battery. The warranty is good too: 72 Month P/R & 2yr Free Replacement |
01-07-2011, 12:17 AM | #14 |
265
Rep 527
Some info on the AutoZone battery in case anyone wanted to consider going that route:
Part Number: H5-DLG Warranty: 8 YR Notes: *** 650 cold cranking Amps (N/A cranking Amps) *** 60 Ah reserve capacity. -> 3 year free replacement <- Battery is vented to outside of vehicle. Installation may take up to 30 minutes. Located in trunk. Price: $124.99 Core: $12.00 Total: $136.99 |
01-07-2011, 12:38 AM | #15 | |
Dog Listener
704
Rep 7,850
01-07-2011, 01:04 AM | #16 |
479
Rep 2,782
Drives: ESS/G-Power Z4M, VF Z4, 996tt
My M's battery was replaced under warranty about 6 months ago, although there was no question as to whether or not I had driven the car enough
I have CPO and the maintenance package, and I'm not sure which one covered it. |
01-07-2011, 08:45 AM | #17 |
19
Rep 389
The car is under warranty until Dec 2011, now I question whether or not to get an extended warranty. The car was jump started back in September and has been daily driven since, however I frequently lose my clock settings or the DSC or TPMS lights come on. The dealer says it's because the battery is dead. I've used a charger though not in AGM mode and didn't change anything.
Is buying a TK the only way to figure out if the battery is dead? Dealer says that using a non BMW battery will void the warranty on the electrical system. I'm currently in NYC on vacation so this sucks trying to figure out if the dealer is trying yo screw me over long distance.
01-07-2011, 09:03 AM | #18 |
851
Rep 4,057
This battery failure stuff simply blows me away.
In addition to our 2009 Accord, we have a 2001 Accord that my wife drives and it is still using the original ten year old battery. The thing would turn over a battleship engine, even on a cold Atlantic Canada winter morning. Prior to that, we had a 1997 Accord from 1997 to 2001. Its battery (and the entire car actually) were 100% failure free for the four years we had the car. I had not a single complaint or repair required for that period. Not even so much as a burnt out light bulb or squeak anywhere. And prior to that, I had an '89 VW Golf Wolfsburg for eight years from 1989 to 1997. The battery never failed in that entire period. And those things were built in Mexico. So. WTF is up with BMW batteries? Its my view that in a premium brand car like a BMW, let alone a specialty car like a Z4, customer driving habits and infrequent use should have been part of the electrical system design and that as a result, battery failures should not be occuring. And if they are, it should be warranty.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. Last edited by Huz-Z; 01-07-2011 at 09:13 AM.. |
01-07-2011, 09:16 AM | #19 |
19
Rep 389
You're comparing a car with plenty of sensors to one without any...
01-07-2011, 09:21 AM | #20 | |
379
Rep 1,002
01-07-2011, 09:30 AM | #21 | |
851
Rep 4,057
And more to the point, its just not acceptable in a BMW.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. |
01-07-2011, 09:53 AM | #22 | |
379
Rep 1,002
