01-03-2011, 10:11 PM | #1 |
Rep 41
Looking to do some upgrades soon
I am in the market for new wheels, pedals a shift knob. I was thinking about some CSL wheels in a 19", but there are so many different brands and sizes.
Does anyone have a set on their M Coupe? I don't want any clearance problems or have to roll the fender. |
01-03-2011, 10:28 PM | #2 |
Dog Listener
703
Rep 7,850
Can't answer your wheel question, but....
Consider adding CDV delete and transmission mounts to that list as well. See this thread (shifters, CDV, transmission mounts)--start at the end of the thread though! Rogue transmission mounts are pretty good replacements as are UUC. Zeckhausen makes a hollowed out CDV if you're still under warranty (otherwise just have it removed or remove it). I can recommend Ultimate Pedals if your thinking about pedals. Mods away! |
01-03-2011, 10:55 PM | #3 |
Rep 41
thanks for the info
I notice that the clutch take alot of getting use to,even then its still hard to get it smooth. I don't understand why BMW put that restriction in the line? If I remove or replace the fitting, would that void the warranty?
01-03-2011, 11:01 PM | #4 | |
Dog Listener
703
Rep 7,850
The Zeckhausen looks stock (as it is, but laser drilled) so it won't set off any immediate red flags. But if the dealer is on the ball (big if) and checked they could tell. Cost about 30 bucks IIRC. Removing it would be a big red flag. Most of us have replaced it with the Zeck because it's such a PITA warranty or not. While we're on the topic of shifting, here's a few more tips: The car tends to grind 1st 2nd at high revs (sometimes lower revs). Pull the shifter down and to the left when going first to second and let the revs equalize a bit....in fact, always pull the shifter left on 1st to 2nd. On normal 1st to 2nd shifts (lower revs, traffic) keep the revs at the level for 2nd (don't let them drop too far) or the car tends to buck. The car tends to not like to go 3rd to 2nd on hard turns (hence the transmission mounts as the stockers are like marshmallows). Some or all of this may be obvious but I thought I'd say it anyway. It's all here, and more, if you search around.... It's a great car with some quirks...all of which can pretty easily be worked around. Last edited by Finnegan; 01-03-2011 at 11:08 PM.. |
01-04-2011, 03:09 AM | #5 |
Viper Driver
36
Rep 1,311
^+1. excellent recommendations with accompanying reasoning. the zeckhausen cdv was my first mod and it made a noticeable difference in terms of gear engagement, especially in 1st and 2nd. u will doubtless already have felt how notchy gears 1 and 2 are and this is perfectly normal, and can be somewhat alleviated with different tranny fluid (rp synchromax is rather popular). also, the bucking bronco type deal at very low revs in 2nd gear is characteristic of the drive-by-wire system, i usually avoid short-shifting from 1st to 2nd just to leave the revs a bit higher up before the shift. alternatively, u could move off in 2nd.
by far the most popular non-oem aftermarket csl reps are the vmr vb3's that are readily available in 18" or 19" and different finishes. they are pretty affordable and can be ordered with near-stock offsets for the z4m's. popular shift knob replacement is moving from stock to zhp. the zhp shift knobs (6-speed non-lighted and lighted variants) can be purchased from leatherz. |
01-04-2011, 03:46 AM | #6 |
44
Rep 380
01-04-2011, 05:42 AM | #7 |
25
Rep 413
Drives: Z4 3.0, CLS63 AMG
Yes, the clutch delay valve can be removed altogether. If you're under warranty then buy the Zeck modified CDV, otherwise just remove the CDV.
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG |
