ZPOST
  TireRack
      12-17-2010, 08:52 AM   #1
paul2241
18
Drives: 2018 BMW 328d Sport Wagon
Climate control not working after jump start
Hello, I must have left something on in my car last night and the battery was dead this morning. I had it jumped, and everything is all right, except for my climate control. It lights up, but will not blow air of any temp. Also the air conditioning and rear defroster buttons are not working. Any ideas?
Thank you.
      12-17-2010, 09:34 AM   #2
wildag
///M'n it Up
wildag's Avatar
17
Drives: '06 ///M Roadster
disconnect the battery for a few minutes and reconnect.
      12-17-2010, 09:41 AM   #3
paul2241
18
Thank you for the tip. I just disconnected, would about 15 minutes be enough? You will be my best friend if you save me a trip to the dealership.
      12-17-2010, 10:07 AM   #4
ToyMaker_GR
Drives: Z4 E85 3.0Si
Hello.
This thread is the reason that I joined this forum. I have the exact same problem with my E85.
Paul, did wildag's tip did the trick for you?
      12-17-2010, 10:10 AM   #5
CFoote
180
Drives: '22 M5CS, '00 M5, '06 Z4M
2022 M5CS  [0.00]
2001 BMW 740i  [0.00]
2006 BMW M Roadster  [0.00]
2012 BMW X6 3.5i  [0.00]
2006 BMW 325xi  [0.00]
2017 BMW 540xi  [0.00]
2000 BMW M5  [0.00]
2001 BMW X5 4.4i  [0.00]
Let's hope so, that climate control module is $500 from the dealer if I remember correctly
If you guys end up need a new module, let me know, I have one in mint condition out of my '05.
Chris
'22 M5CS, '06 Z4M, '01 X5 4.4i, '00 M5, '05 Acura RL, '12 X6 3.5, '01 740, 08 335xi, '17 540xi (yes they all are still with me)
      12-17-2010, 10:37 AM   #6
paul2241
18
That did not work. Any other ideas?
      12-17-2010, 11:00 AM   #7
pokeybritches
pokeybritches's Avatar
479
Drives: ESS/G-Power Z4M, VF Z4, 996tt
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Is there a fuse to check?
      12-17-2010, 11:02 AM   #8
Diokaef
Engineer
Diokaef's Avatar
216
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
It may be a fuse, check behind the clove box.
      12-17-2010, 11:03 AM   #9
paul2241
18
Also my auto up windows are no longer working.
      12-17-2010, 11:08 AM   #10
Diokaef
Engineer
Diokaef's Avatar
216
Also it could be your battery reading less then 12.65v very common thing that gives all kind troubles. Solution: Remove battery complete out of the car and charge it to 13.5 -13.75 range, no more then that, let the battery sit out of the car for at list 6-8 hours after it's charged then reinstall the battery (+) first (-)neutral last
      12-17-2010, 11:12 AM   #11
Diokaef
Engineer
Diokaef's Avatar
216
It happened to me and freaked me out, Also before you put the battery back on the car make sure it still above 12.65v reading otherwise your battery is bad.
      12-17-2010, 12:18 PM   #12
paul2241
18
The battery is at 12.8 when the vehicle is completely off.
      12-17-2010, 12:42 PM   #13
ToyMaker_GR
Well, the BMW service told me the whole control unit needs to be replaced.
This thing costs 500+ euros if new (I live in Greece)...
I just purchased a used part from eBay, and will try to place it myself when it arrives, it shouldn't be that hard, it just has a screw on top and two connectors at the back as far as I can tell by the blueprints (I bet BMW would charge me 100+ euros just for the placement)...
I hope Paul this is not the case for you and the thing is not broken like mine.
      12-17-2010, 02:40 PM   #14
CFoote
180
2022 M5CS  [0.00]
2000 BMW M5  [0.00]
Best bet is to remove the Radio and Vents above radio, then remove panel below climate control. From there you should be able to easily remove it. If I remember there are clips on the left and right side of the unit in addition to the 2 screws, so becareful and do not break them (you'll see what I mean when you get the replacement unit and see it)
Chris
      12-17-2010, 02:42 PM   #15
CFoote
180
2022 M5CS  [0.00]
2000 BMW M5  [0.00]
How long did you disconnect for? Try overnight.
The lack of Auto Up/Down windows is normal any time you disconnect the battery, the sensors do not know where the window is. There is a sequence you have to do to bring them back (search the forum, I've forgotten the sequence).
As mentioned above, check any Fuses that deal with the Climate Control.
Chris
      12-17-2010, 05:33 PM   #16
paul2241
18
It turns out my car was in transport mode. BMW charged me $60 to turn that mode off and told me I have a bad cell in the battery. They want $425 for a new battery plus an hour labor. Took it to auto zone, they said the battery tested fine. Now I don't know what to do.
      12-17-2010, 06:31 PM   #17
pokeybritches
479
2006 BMW Z4M  [8.50]
Does the climate control work now?
I've left on lights before, and the car usually shuts them off when it senses a drain.
      12-17-2010, 09:26 PM   #18
Finnegan
Dog Listener
Finnegan's Avatar
703
Drives: Z4M/. Z3M, E36/46 M3
Does that work on the M, or the 3.0? Wife left the lights on today on the ///M, and the battery totally crapped out. Had to have AAA jump it. Battery did take a charge, but is at the end of its life (have to replace it this weekend). So perhaps that's why the feature didn't work (current drain cutoff assumes a certain level of battery capacity, battery is more or less toast, it didn't catch it in time....).
      12-18-2010, 01:02 AM   #19
Diokaef
Engineer
Diokaef's Avatar
216
http://cgi.ebay.com/ebaymotors/03-05...ht_2910wt_1167
      12-18-2010, 02:46 AM   #20
ToyMaker_GR
Check this out: http://www.bimmerforums.co.uk/forum/...roblem-t44239/
Exact same problem, "transport mode" the issue. God I love Google.
I will visit the BMW service asap to check it out.
      12-18-2010, 04:49 AM   #21
pokeybritches
479
2006 BMW Z4M  [8.50]
I believe it's both. I don't recall ever leaving a light on in the 3.0i, but I've done it in the M. My center console light was stuck on for about a month because the tab broke off.
Interestingly, when the battery started to crap out on the 3.0i it gave me fair warning. The car started weaker and weaker each day for several weeks; if this ever happens to anyone else, replace the battery ASAP because I ended up killing the starter as well. With the M, I went to start it one day and it was completely dead. No warning at all. The windows wouldn't even seal closed after closing the door. Each time I opened and closed the car door they would dip down a bit but not have enough power to go back up. By the time the tow truck arrived, they were at half mast
The driver of the tow truck made me feel like an idiot. He asked me to pop the hood to jump the car, and when I explained that the battery was in the trunk he pointed to the positive terminal near the firewall. I'd been pulling apart my trunk to trickle charge my 3.0i for years for no reason
      12-18-2010, 10:47 AM   #22
XMetal
XMetal's Avatar
1136
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
How long does it usually takes you guys to crank the starter before the M actually starts? My MC usually takes 1 - 2 seconds of cranking before the engine fires up. Does this sound normal? My X5 usually fires right up within half a second or so.
zpost
