12-05-2010, 03:43 AM | #1 |
274
Rep 662
Best iPod kits
I did a search but there are so many posts I don't know where to start, therefore can anyone recommend the best iPod/iPhone 4 kits?
Is the oem the best, or are after markets ones the same or better? Thanks heaps |
12-05-2010, 07:40 AM | #2 |
Rep 133
Drives: 2006 Silver BMW Z4MR
i use a dice unit, i got it from Bavarian sound werks and i'm pretty happy with it
http://www.bavsound.com/ |
12-05-2010, 03:52 PM | #4 |
180
Rep 700
I have the DICE Silverline kit.
wildag is correct, the DICE kit does have limitations, but everything in this World has limits. I have limitations, you have limitations, it is just a matter of what limitations you can live with. For my needs the DICE unit is fine. Which ever unit you ultimately go for in the end make sure you order the radio interface kit not the trunk interface kit. The trunk interface kit induces unacceptable hum and interference because of the excessive cable length and the routing location of the factory cable. I understand that this issue is a common complaint of the Intravee II system too when used with the trunk interface wiring harness. With the radio interface wiring harness I get crystal clear performance.
Nitron NTR R3 | StopTech Trophy Sport STR-60 380x32mm / StopTech Trophy Sport STR-40 355x32mm | Bridgestone RE-71RS | ADV.1 | CDV Delete | TMS Rear Camber Arms | RE Diablo's | 4.10 Gears | Euro Headers | RTD REVO1 Short Shifter
12-05-2010, 04:12 PM | #5 | |
///M'n it Up
17
Rep 344
I have the "trunk" (actually rear console on the Z4) interface connected to my Intravee II and it has no interference (even with several extra yards of cables stuffed in there). The interference is induction noise from the battery lines that run from the trunk to the engine. Longer cars, like the 3 series, will have more interference than our relatively short Z4. A simple loading coil around the ipod adapter cable should fix the problem. |
12-05-2010, 04:16 PM | #6 |
Looking for a track car
Rep 242
Drives: 2006 325xi wagon
Dice works fine right up to when you want to see or read the navi while in Dice mode. Sucks. Have to stop listening to music just to see the map. Also, if I touch the tone to tweek the bass or treble, it changes tracks instead of making the actual tone adjustments. Wouldn't recommend it, and would strongly discourage it if you saw what it does, or doesn't do, in person.
12-05-2010, 04:19 PM | #7 | |
///M'n it Up
17
Rep 344
Finally, they told me that if I wanted to use the Navigation, I simply had to go through a 6 button process to turn off the song title text on the DICE. And then when I wanted it back, do the same 6 button process. I was told that's DICE's official position on the "non-issue". I smashed my DICE Silverline Pro unit about 2 days after DICE tech support told me that. |
12-05-2010, 04:25 PM | #8 | |
180
Rep 700
I can look at the Nav map and listen to music from the DICE at the same time. Also I have never had it play up with faulty function operation.
12-05-2010, 04:38 PM | #9 |
///M'n it Up
17
Rep 344
Does your unit show the song title text,and allow you to use the navigation at the same time?
12-05-2010, 04:59 PM | #10 | |
180
Rep 700
Like DICE users some Intravee II users will be fine with the trunk interface kit while others will have a problem with static. If you check the Intravee forums and search 'static' you will find many users complain of this static issue too.
12-05-2010, 05:04 PM | #11 |
148
Rep 1,100
I have never had any problems with my intravee II, and I have not seen one complaint here or on e46fanatics about the unit. On the other hand I have seen dozens of complaints about the various dice units.
12-05-2010, 05:07 PM | #12 | |
180
Rep 700
When I am using the Nav map I am looking where I am going and watching traffic. I can already hear what I am listening to so it is not like I have to see the name or artist of the song unless I am searching for a track to album to play.
12-05-2010, 06:50 PM | #15 |
Car Guy
31
Rep 796
Nothing BUT issues with my Dice unit, Intravee II is MUCH better and has been trouble and noise free.
12-05-2010, 08:34 PM | #16 | |
///M'n it Up
17
Rep 344
My point is that the DICE doesn't do what its advertised to do. |
12-05-2010, 09:00 PM | #17 |
140
Rep 1,991
Interesting comments on the noise. My OEM adapter, which is in the dash, has a horrible amount of hiss. I can hear it on quiet and sometimes even the main parts of the songs. Sometimes it goes away for short periods, but is almost always there on some level. I have tried changing cables from the unit and even tried another main adaptor unit to no avail. I wonder about the "loading coil" Wildag mentioned. Maybe this would solve my problem. I am considering changing to the new DICE or Intravee II due to the noise, but would love it if I could fix it without the expense and hassle of replacing the OEM unit. The OEM Audi Music Interface in my wifes car makes no such noise.
12-06-2010, 02:49 PM | #18 |
35
Rep 184
With the Intravee II do I need the Alpine Ipod bit too, or does it use the existing iPod connector in the glove box on the M coupe? The BMW iPod interface is pretty bad....
12-06-2010, 03:54 PM | #19 |
///M'n it Up
17
Rep 344
You need the Intravee II and the KCA-420i Alpine iPod adapter. Get the KCA-420i on eBay or Amazon.
12-08-2010, 08:59 PM | #20 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
all this talk bout intravee ii but is there even a place that sells this anymore? i searched for a long time and couldn't find a place.
12-08-2010, 09:02 PM | #21 |
509
Rep 1,345
Drives: 04 Z4, 18 X3 M40i
Have the BMW adapter kit - keep the ipod in the glove box. No hiss, steering wheel controls. No detail as to which song in playing but I tend to pay more attention to what is outside. No hiss or other sound issues.
12-08-2010, 09:36 PM | #22 | |
Rep 421
http://www.bimmerfest.com/forums/sho...9&postcount=27 http://www.bimmerfest.com/forums/sho...d.php?t=297113 |
